[GRASS-user] i.atcorr with Sentinel2
Markus Metz
markus.metz.giswork at gmail.com
Tue Jan 23 05:50:23 PST 2018
On Tue, Jan 23, 2018 at 2:19 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> OK, will give it a try.
The first part is more important because it 1) fixes the interpolation to
2.5 nm steps, and 2) helps iwave.cpp to load the response values.
> For the second part I am not sure if I properly understood where min –
max wavelength for each band should be printed to.
> Do you mean to replace
> # convert limits from nanometers to micrometers
> lowerlimit = wavelengths[0]/1000
> upperlimit = wavelengths[-1]/1000
> Or just as a screen output?
Just a screen output to help update the manual
> You did not mean band value limits, right?
No, e.g. in the manual is
Sentinel2A Coastal blue band B1 (430nm - 457nm)
and this range could be printed out to screen based on the actual response.
This range can then be copied to the manual, making life a bit easier for
the person updating the manual.
> Not sure I am of help/useful for fixing create_iwave.py, but I`ll do my
best…
Your help is welcome!
Markus M
> Cheers
> Stefan
> From: Markus Metz [mailto:markus.metz.giswork at gmail.com]
> Sent: tirsdag 23. januar 2018 13.02
> To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> Cc: Markus Neteler <neteler at osgeo.org>; GRASS user list <
grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] i.atcorr with Sentinel2
> On Tue, Jan 23, 2018 at 12:25 PM, Stefan Blumentrath <
> > No problem. Any chance I can contribute to maintenance of
create_iwave.py?
> > What needs to be done? Take your latest changes into account?
> nodata handling should be changed. In read_input(), missing values should
be set to zero. Then for each band, leading and trailing zeros would be set
to -1. This helps interpolate_band() to get the correct subrange.
> For each band, create_iwave.py should print out the band name and the
wavelength as min - max. Care must be taken when finding reasonable min and
max wavelengths: find the max response, then go back while response >
threshold to find the min wavelength. Go forward while response > threshold
to find the max wavelength. As threshold I suggest 0.1 to eliminate noise
in the response values.
> Markus M
> > If you think it makes sense I will try to create a patch for adding S2B
to i.atcorr (would be a nice exercise and does not seem too complex)? Will
open a ticket and start working on it unless you tell me different.
> > Cheers
> > Stefan
> > From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf
Of Markus Metz
> > Sent: tirsdag 23. januar 2018 12.03
> > To: Markus Neteler <neteler at osgeo.org>
> > Cc: GRASS user list <grass-user at lists.osgeo.org>
> > On Tue, Jan 23, 2018 at 11:51 AM, Markus Neteler <
> > neteler at osgeo.org> wrote:
> > > On Tue, Jan 23, 2018 at 11:09 AM, Žofie Cimburová
> > zoficimburova at gmail.com> wrote:
> > > > Forgot to cc the list.
> > > > The CSV and the cpp template:
https://www.dropbox.com/sh/9cnhsl59kvmx4o1/AABwnEVHdxfW_PqrB5Xcpczda?dl=0
> > > Great! Would you mind to also convert the S2A table? AFAIK it got
> > > updated due to recalibration compared to what we currently have.
> > please wait a bit with creating the cpp template, create_iwave.py needs
some maintenance
> > Markus M
> > > markusN
> > > _______________________________________________
> > > grass-user mailing list
> > > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180123/99969316/attachment.html>
