[GRASS-user] i.atcorr with Sentinel2
Markus Metz markus.metz.giswork at gmail.com
Tue Jan 23 06:30:57 PST 2018
On Tue, Jan 23, 2018 at 3:24 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> OK, sounds doable for me ;-).
> Will look at it tonight. Most of the other changes for Sentinel-2B are
already in place (I hope).
Great!
> Not sure if I manage to add python tests as well, looks like current
tests are more manual?
Apparently results differ between operating systems, therefore tests won't
work well, unless you test if the output is all NULL, in which case a fatal
error should be produced anyway.
Markus M
> Cheers
> Stefan
> ________________________________________
> Von: Markus Metz [markus.metz.giswork at gmail.com]
> Gesendet: Dienstag, 23. Januar 2018 14:50
> An: Stefan Blumentrath
> Cc: Markus Neteler; GRASS user list
> Betreff: Re: [GRASS-user] i.atcorr with Sentinel2
> On Tue, Jan 23, 2018 at 2:19 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> wrote:
> > OK, will give it a try.
> The first part is more important because it 1) fixes the interpolation to
2.5 nm steps, and 2) helps iwave.cpp to load the response values.
> > For the second part I am not sure if I properly understood where min -
max wavelength for each band should be printed to.
> > Do you mean to replace
> >     # convert limits from nanometers to micrometers
> >     lowerlimit = wavelengths[0]/1000
> >     upperlimit = wavelengths[-1]/1000
> > Or just as a screen output?
> Just a screen output to help update the manual
> > You did not mean band value limits, right?
> No, e.g. in the manual is
> Sentinel2A Coastal blue band B1 (430nm - 457nm)
> and this range could be printed out to screen based on the actual
response. This range can then be copied to the manual, making life a bit
easier for the person updating the manual.
> > Not sure I am of help/useful for fixing create_iwave.py, but I`ll do my
best.
> Your help is welcome!
> Markus M
> > Cheers
> > Stefan
> > From: Markus Metz [mailto:markus.metz.giswork at gmail.com<mailto:
markus.metz.giswork at gmail.com>]
> > Sent: tirsdag 23. januar 2018 13.02
> > To: Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:
> > Cc: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>; GRASS
user list <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
> > Subject: Re: [GRASS-user] i.atcorr with Sentinel2
> > On Tue, Jan 23, 2018 at 12:25 PM, Stefan Blumentrath <
> > > No problem. Any chance I can contribute to maintenance of
create_iwave.py?
> > > What needs to be done? Take your latest changes into account?
> > nodata handling should be changed. In read_input(), missing values
should be set to zero. Then for each band, leading and trailing zeros would
be set to -1. This helps interpolate_band() to get the correct subrange.
> > For each band, create_iwave.py should print out the band name and the
wavelength as min - max. Care must be taken when finding reasonable min and
max wavelengths: find the max response, then go back while response >
threshold to find the min wavelength. Go forward while response > threshold
to find the max wavelength. As threshold I suggest 0.1 to eliminate noise
in the response values.
> > Markus M
> > > If you think it makes sense I will try to create a patch for adding
S2B to i.atcorr (would be a nice exercise and does not seem too complex)?
Will open a ticket and start working on it unless you tell me different.
> > > Cheers
> > > Stefan
> > > From: grass-user [mailto:grass-user-bounces at lists.osgeo.org<mailto:
grass-user-bounces at lists.osgeo.org>] On Behalf Of Markus Metz
> > > Sent: tirsdag 23. januar 2018 12.03
> > > To: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
> > > Cc: GRASS user list <grass-user at lists.osgeo.org<mailto:
> > > On Tue, Jan 23, 2018 at 11:51 AM, Markus Neteler <
> > > neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
> > > > On Tue, Jan 23, 2018 at 11:09 AM, Žofie Cimburová
> > > zoficimburova at gmail.com<mailto:zoficimburova at gmail.com>> wrote:
> > > > > Forgot to cc the list.
> > > > > The CSV and the cpp template:
https://www.dropbox.com/sh/9cnhsl59kvmx4o1/AABwnEVHdxfW_PqrB5Xcpczda?dl=0
> > > > Great! Would you mind to also convert the S2A table? AFAIK it got
> > > > updated due to recalibration compared to what we currently have.
> > > please wait a bit with creating the cpp template, create_iwave.py
needs some maintenance
> > > Markus M
> > > > markusN
> > > > _______________________________________________
> > > > grass-user mailing list
> > > > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180123/782d131b/attachment.html>
