[GRASS-user] Declaration of GLOBAL variable fail in GRASS7
    Markus Metz
    markus.metz.giswork at gmail.com
    Tue Jan 23 11:54:22 PST 2018
On Tue, Jan 23, 2018 at 12:01 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jan 22, 2018 at 2:04 PM, Marino Vetuschi Zuccolini
> <zucco at dipteris.unige.it> wrote:
> > Hello to all,
> > I’m trying to use well tested shell scripts with grass5/6 packages with
a
> > more recent grass7 in Mint distribution (from
ppa:ubuntugis/ubuntugis-stable)
> > realising a singular error:
> > ERROR: Variable ‘LOCATION_NAME’ not set
> > despite the variable declaration (with "export" keyword in bash) is
made INSIDE the script
> > or in the directly in the terminal.
> Do you intend to run GRASS GIS in a terminal without being explicitely
> in a session?
> If yes, please see here for instructions:
https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Bash_examples_.28GNU.2FLinux.29
As you can see there, LOCATION_NAME is not an environment variable, but a
GRASS variable stored in $GISRC. The relevant code sniplet is
# Set the global grassrc file to individual file name
MYGISRC="$HOME/.grassrc.$GRASS_VERSION.$$"
echo "GISDBASE: $MYGISDBASE" > "$MYGISRC"
echo "LOCATION_NAME: $MYLOC" >> "$MYGISRC"
echo "MAPSET: $MYMAPSET" >> "$MYGISRC"
echo "GRASS_GUI: text" >> "$MYGISRC"
# path to GRASS settings file
export GISRC=$MYGISRC
HTH,
Markus M
> Furthermore, due to flags and parameters standardization, some (minor)
> changes my be needed in your scripts:
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures74#MigratingfromGRASSGIS6toversion7.x
> (at page bottom)
> Best,
> Markus
> Markus Neteler, PhD
> http://www.mundialis.de - free data with free software
> http://grass.osgeo.org
> http://courses.neteler.org/blog
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180123/1f15b201/attachment.html>
