[GRASS-user] i.atcorr with Sentinel2
Nikos Alexandris
nik at nikosalexandris.net
Wed Jan 24 01:14:15 PST 2018
* Markus Metz <markus.metz.giswork at gmail.com> [2018-01-23 13:02:27 +0100]:
>On Tue, Jan 23, 2018 at 12:25 PM, Stefan Blumentrath <
>Stefan.Blumentrath at nina.no> wrote:
>> No problem. Any chance I can contribute to maintenance of create_iwave.py?
>> What needs to be done? Take your latest changes into account?
>nodata handling should be changed. In read_input(), missing values should
>be set to zero. Then for each band, leading and trailing zeros would be set
>to -1. This helps interpolate_band() to get the correct subrange.
>For each band, create_iwave.py should print out the band name and the
>wavelength as min - max. Care must be taken when finding reasonable min and
>max wavelengths: find the max response, then go back while response >
>threshold to find the min wavelength. Go forward while response > threshold
>to find the max wavelength. As threshold I suggest 0.1 to eliminate noise
>in the response values.
>Markus M
Thanks Markus for this one (too). Back in Bonn 2016, I tried to clear
up some of it. Not exactly the way it had/has to be done as I
understand now.
Nikos
>> If you think it makes sense I will try to create a patch for adding S2B
>to i.atcorr (would be a nice exercise and does not seem too complex)? Will
>open a ticket and start working on it unless you tell me different.
>> Cheers
>> Stefan
>> From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of
>Markus Metz
>> Sent: tirsdag 23. januar 2018 12.03
>> To: Markus Neteler <neteler at osgeo.org>
>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>> Subject: Re: [GRASS-user] i.atcorr with Sentinel2
>> On Tue, Jan 23, 2018 at 11:51 AM, Markus Neteler <
>> neteler at osgeo.org> wrote:
>> > On Tue, Jan 23, 2018 at 11:09 AM, Žofie Cimburová
>> zoficimburova at gmail.com> wrote:
>> > > Forgot to cc the list.
>> > > The CSV and the cpp template:
>> https://www.dropbox.com/sh/9cnhsl59kvmx4o1/AABwnEVHdxfW_PqrB5Xcpczda?dl=0
>> > Great! Would you mind to also convert the S2A table? AFAIK it got
>> > updated due to recalibration compared to what we currently have.
>> please wait a bit with creating the cpp template, create_iwave.py needs
>some maintenance
>> Markus M
>> > markusN
>> > _______________________________________________
>> > grass-user mailing list
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180124/c8f383de/attachment.sig>
