[GRASS-user] Issue with addon r.vif in MS Windows GUI installations (stand-alone v. 7.2.2 and 7.0.5)
Dinarzarde Raheem
d.raheem at nhm.ac.uk
Wed Jan 31 08:10:21 PST 2018
I have been trying to run the addon r.vif using Grass for MS Windows standalone v. 7.2.2 and v. 7.0.5 on three separate PCs (two have Windows 7 32bit/64 bit, one runs Windows 10 Home 64 bit). I have been testing the r.vif installation using the example on the r.vif page of the Grass 7 addons manual (i.e. this uses the GRASS 7 Climatic data time series NC location nc_climate_spm_2000_2012).
With v. 7.2.2 (in both Windows 7 and 10) I can load the extension, and can visualise Addons in the search modules tab, but the r.vif. tool is not visible under Addons.
With v. 7.0.5 (in both Windows 7 and 10), I can load r. vif, visualise it under Addons in the Search Modules tab and run it, but I get the following error message:
(Wed Jan 31 15:06:21 2018)
r.vif maps=2011_01_precip at climate_1970_2012,2011_02_precip at climate_1970_2012,2011_03_precip at climate_1970_2012,2011_04_precip at climate_1970_2012,2011_05_precip at climate_1970_2012,2011_06_precip at climate_1970_2012,2011_07_precip at climate_1970_2012,2011_08_precip at climate_1970_2012,2011_09_precip at climate_1970_2012,2011_10_precip at climate_1970_2012,2011_11_precip at climate_1970_2012,2011_12_precip at climate_1970_2012 maxvif=10 file=C:\grassworkspace\2011test
Reading in the data ...
File "C:\Users\dinr\AppData\Roaming\GRASS7\addons/scripts/
r.vif.py", line 365, in <module>
sys.exit(main(*gs.parser()))
r.vif.py", line 226, in main
p = ReadData(IPF, n)
r.vif.py", line 156, in ReadData
os.remove(tmpcov)
WindowsError: [Error 32] The process cannot access the file
because it is being used by another process:
'c:\\users\\dinr\\appdata\\local\\temp\\tmpsggohd'
(Wed Jan 31 15:06:25 2018) Command finished (4 sec)
Is there anything I can do to fix this issue?
Dinarzarde
Dr. Dinarzarde Raheem
Scientific Associate
Life Sciences Department
The Natural History Museum
London SW7 5BD
UK
Tel: +44 (0) 20 7942 5289
Fax: +44 (0) 20 7942 5216
E-mail: dinr at nhm.ac.uk
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180131/421898e6/attachment.html>
