[GRASS-user] Switching databases for holding attributes in Grass 7.4.1
Paul Shapley p.shapley at gmail.com
Mon Jul 2 06:25:11 PDT 2018
Hi Markus,
I used 'db.connect' followed by 'db.login'
Please see below:-
db.connect -p
driver: sqlite
database: C:\\TempLocation\PERMANENT\sqlite\sqlite.db
schema: grass_gis
group: postgis_reader
(Mon Jul 02 14:17:04 2018) Command finished (0 sec)
db.connect -d
Default driver / database set to:
driver: sqlite
(Mon Jul 02 14:19:40 2018) Command finished (0 sec)
Still holding 'schema' and 'group' details from PostGIS. Shouldn't these
have been dropped when changing to sqlite which is perhaps why the
connection is failing?
On 2 July 2018 at 14:10, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> On Mon, Jul 2, 2018 at 2:00 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> > Hi Users,
> > I want to use 'r.to.vect' but it seems to default to a 'Postgis' table
> that has no geometry column just a table with a 'cat' id. I would like to
> export to 'sqlite'. I have both postgres an sqlite login details stored in
> 'db.login'. How do i switch between the two or at least make sqlite the
> default? If I change settings with 'db.connect' to 'sqlite'
> what is the exact command you used to set the default connection to sqlite?
> You can also try db.connect -d, otherwise you might need to specify the
> default database to be used.
> In any case, please verify first with db.connect -p to see the connection
> details used when creating a new vector.
> Markus M
> > it fails (error below) but still keeps holding onto the 'grass_gis'
> schema form the Postgis connection!
> > r.to.vect input=APGB_aerial_2_i_segment_drained_peat_with_exposed_
> haggs at PERMANENT output=test1 type=area
> > DBMI-SQLite driver error:
> > Error in sqlite3_prepare():
> > unknown database grass_gis
> > ERROR: Unable to create table: create table grass_gis.test1 ( cat
> integer, value integer, label varchar(10))
> > WARNING: Table <grass_gis.test1> linked to vector map <test1> does not
> exist
> > Is there a preferred option to change databases more cleanly.
> > Many thanks,
> > Paul J. Shapley MSc CGeog (GIS) FRGS
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
*Paul J. Shapley *MSc CGeog (GIS) FRGS
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180702/c0d655c6/attachment.html>
