[GRASS-user] Switching databases for holding attributes in Grass 7.4.1
Paul Shapley
p.shapley at gmail.com
Mon Jul 2 07:04:46 PDT 2018
Hi Markus,
Used 'db.connect' driver=sqlite
database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
*I had to delete* 'database schema=grass_gis'
*I had to delete* 'default group=postgis_reader'
Then 'RUN'
output:-
(Mon Jul 02 14:59:21 2018)
db.connect
(Mon Jul 02 14:59:22 2018) Command finished (1 sec)
now attempted 'r.to.vect'
r.to.vect
input=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs at PERMANENT
output=test1 type=area
DBMI-SQLite driver error:
Error in sqlite3_prepare():
unknown database grass_gis
ERROR: Unable to create table: create table grass_gis.test1 ( cat integer,
value integer, label varchar(10))
WARNING: Table <grass_gis.test1> linked to vector map <test1> does not exist
Repeat as above!!
Then 'RUN'
On 2 July 2018 at 14:41, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> On Mon, Jul 2, 2018 at 3:25 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> > Hi Markus,
> > I used 'db.connect'
> which flags/options did you use?
> > followed by 'db.login'
> you don't need db.login for sqlite
> > Please see below:-
> > db.connect -p
> > driver: sqlite
> > database: C:\\TempLocation\PERMANENT\sqlite\sqlite.db
> > schema: grass_gis
> > group: postgis_reader
> > (Mon Jul 02 14:17:04 2018) Command finished (0 sec)
> > db.connect -d
> > Default driver / database set to:
> > driver: sqlite
> > (Mon Jul 02 14:19:40 2018) Command finished (0 sec)
> > Still holding 'schema' and 'group' details from PostGIS. Shouldn't these
> have been dropped when changing to sqlite which is perhaps why the
> connection is failing?
> yes.
> It seems that db.connect -g is better than db.connect -p to verify
> connection settings, e.g. I get in the North Carolina sample dataset
> > db.connect -g
> driver=sqlite
> schema=
> group=
> The database is not a real path but contains GRASS variables that are
> evaluated on the fly. This is the default connection.
> Markus M
> > On 2 July 2018 at 14:10, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
> >> On Mon, Jul 2, 2018 at 2:00 PM, Paul Shapley <p.shapley at gmail.com>
> wrote:
> >> > Hi Users,
> >> > I want to use 'r.to.vect' but it seems to default to a 'Postgis'
> table that has no geometry column just a table with a 'cat' id. I would
> like to export to 'sqlite'. I have both postgres an sqlite login details
> stored in 'db.login'. How do i switch between the two or at least make
> sqlite the default? If I change settings with 'db.connect' to 'sqlite'
> >> what is the exact command you used to set the default connection to
> sqlite?
> >> You can also try db.connect -d, otherwise you might need to specify the
> default database to be used.
> >> In any case, please verify first with db.connect -p to see the
> connection details used when creating a new vector.
> >> Markus M
> >> > it fails (error below) but still keeps holding onto the 'grass_gis'
> schema form the Postgis connection!
> >> > r.to.vect input=APGB_aerial_2_i_segment_drained_peat_with_exposed_
> haggs at PERMANENT output=test1 type=area
> integer, value integer, label varchar(10))
> not exist
> >> > Is there a preferred option to change databases more cleanly.
> >> > Many thanks,
> >> > Paul J. Shapley MSc CGeog (GIS) FRGS
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
*Paul J. Shapley *MSc CGeog (GIS) FRGS
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180702/65a40ee7/attachment-0001.html>
