[GRASS-user] Possible Grass Bug
Nikos Alexandris
nik at nikosalexandris.net
Mon Jul 2 23:38:45 PDT 2018
* Rich Shepard <rshepard at appl-ecosys.com> [2018-06-30 16:04:33 -0700]:
>On Sun, 1 Jul 2018, ubuntu wrote:
>>What is the difference between the console at the layer manager tab and
>>the GRASS 7.4.0 (nc_spm_08_grass7):~ > at the ubuntu terminal? when should
>>I use the console and when the other one? And what is the difference
>>between wx0,1,2, ... windows and the Grass GIS Map Display window (the one
>>that loads along with the layer manager)?
>Nozhan,
> You will find that you have more control working at the console,
>particularly when the wxGUI does not recognize files you want to use. The
>GUI can be quite useful, but working at the console is preferred by those
>who are used to working on consoles in linux, *BSD, and various unices.
>Also, you can write scripts to perform repetative or complex processes and
>run them from the command line. The GUI does not support this.
Please note that (Python) scripting is possible via the GUI as well. There is a
Python tab and a simple Python script editor integrated (since at least
version 7.4). Simple examples are also included. I don't use them, so I don't
have an opinion about their usability.
There is also the wxGUI Graphical Modeler. It too has the script
editor integrated. In 2008, I requested for such an option:
https://trac.osgeo.org/grass/ticket/131. Not speaking Python at the time,
I asked for help to learn. I think it can be a good starting point in Python
scripting for GRASS GIS. The 'Help' menu offers links to various
resources. Adding one or two more resources, like
https://github.com/wenzeslaus/python-grass-addon, is meaningful.
Nikos
> Either on a 'getting started' or wiki page is a list of commands to start
>grass. In your installation 'grass' and 'grass74' are synonymous. If you run
>multiple versions (e.g., 7.4.x and 7.5svn) then you want to assign each to a
>unique name.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180703/e6cf2c5b/attachment.sig>
