[GRASS-user] Finding EPSG code based on prj.adf; importing with v.in.gdal
Markus Metz
markus.metz.giswork at gmail.com
Thu Jul 5 00:00:45 PDT 2018
On Thu, Jul 5, 2018 at 12:44 AM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> The ESRI GRID formatted LiDAR raw data file can be imported using
> r.in.gdal using the appropriately defined location. Running 'gdalinfo
> <filename> | less' on the prj.adf file reports:
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
> DATUM["Not_specified_based_on_GRS_1980_ellipsoid",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","6019"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4019"]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["standard_parallel_1",44.33333333333334],
> PARAMETER["standard_parallel_2",46],
> PARAMETER["latitude_of_origin",43.66666666666666],
> PARAMETER["central_meridian",-120.5],
> PARAMETER["false_easting",8202099.737532808],
> PARAMETER["false_northing",0],
> UNIT["user-defined",0.3048]]
> Origin = (7719274.500000000000000,628402.500000000000000)
> Pixel Size = (3.000000000000000,-3.000000000000000)
> Looking up EPSG:4019 on the web shows me that it's an "Unknown datum
> ellipsoid."
EPSG:4019 is not the EPSG code of the SRS, but of one of its components
(there are 5 different EPSG codes within this SRS). The SRS itself does not
have an EPSG code, therefore you can create a new location with g.proj
georef= or r.in.gdal location=
Markus M
> I created a new location, named EPSG4019, selected that code for the
> projection, and ran 'r.in.gdal -o
in=$HOME/path_to/data/topography/LDQ-45122C3/2009_OLC_Hood-to-Coast/Bare_Earth/\
> be45122c3/hdr.adf out=dem2009 --overwrite' (Entered on one line; split
here
> for MUA accommodation.) grass75 responds,
> WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not recognised
> by GRASS and no parameters found
> Over-riding projection check
> ERROR: Illegal latitude for North: 628402
> Please show me what I've done incorrectly.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180705/5bbfc904/attachment.html>
