[GRASS-user] Finding EPSG code based on prj.adf; importing with v.in.gdal
Daniel Victoria
daniel.victoria at gmail.com
Fri Jul 6 04:32:09 PDT 2018
The prj.adf says you have a Lambert Conformal Conic. Since you are working
with data from oregon, a quick search in Spatialreference.org resulted in
this:
Oregon State Plane
http://spatialreference.org/ref/sr-org/7327/
Thake a look at the HUman readable OGC WKT. Looks the same.
I don't think there is a EPSG code for this but, as Markus wrote, you can
use r.in.gdal to create a location based on your file
Cheers
Daniel
On Thu, Jul 5, 2018 at 9:46 AM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Thu, 5 Jul 2018, Markus Metz wrote:
> > EPSG:4019 is not the EPSG code of the SRS, but of one of its components
> > (there are 5 different EPSG codes within this SRS). The SRS itself does
> > not have an EPSG code, therefore you can create a new location with
> g.proj
> > georef= or r.in.gdal location=
> Markus,
> I wondered about 4019; most SRS reports have a legitimate EPSG code as
> the
> final one and I was uncertain about this one.
> So I'll have grass figure out the appropriate projection from the
> prj.adf
> file.
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180706/befd7404/attachment.html>
