[GRASS-user] Setting region to add map to location
Rich Shepard
rshepard at appl-ecosys.com
Mon Jul 9 10:44:37 PDT 2018
On Mon, 9 Jul 2018, Markus Metz wrote:
> first set the region to match the raster:
> g.region raster=elwood_dem2013
> now proceed as before:
Markus,
Okay. I thought the vector box matched that of the raster. I'll make that
change.
> this:
>> nsres=0.99999517
>> ewres=1.00000368
> is probably not what you want, it is recommended to align the region to
> exactly 1 map unit:
> g.region -p -a res=1
> before reprojection
I think this is what I did:
>> g.region vect=elwood_reproj res=1 -a
>> r.proj loc=elwood map=PERMANENT in=elwood_dem2013 res=1 method=lanczos
> You should notice a difference when using the suggested g.region calls.
I'll set the source region to the raster map prior to creating the vector
box. Will post results.
Thanks,
Rich
