[GRASS-user] r3.in.xyz
Francois Chartier
fra.chartier at gmail.com
Wed Jul 11 18:54:30 PDT 2018
Hi Moritz, Thanks for your email. What you described is the concept for
developing most geological model by correlating top of layers (rock, soils,
formation etc.) which is the correct approach when geological contacts are
clear.
In my case (as part of a masters/engineering degree), I have so much data
and i am interpolating soils, that i am trying another approach where i
will be interpolating a property in 3D. Although there are some regional
conceptual models in my areas, we often find that reality differs quite a
bit from the conceptual understanding of the area. Therefore i am
attempting to develop a ''newish" approach by interpolating the data set by
using a numerical property for the soil type.
I will be interpolating most likely particle size (x mm for sand, x mm for
silts, x mm for clays etc), and hydraulic conductivity (K). This could be
any parameters such as moisture content, geotech blow counts,
concentrations etc.
That said, from the borehole information, the soil type or particle size is
constant until the next underlying formation. However, the data base only
provide the property at the top of the formation (ex: silt) like typical BH
databases. Once the interpolation is completed, i can identify the soils
by the color coding and custom scales.
So i am wondering if in Grass, i need to generate a property (particle
size, K) for each meter of elevation so that i have a data point in between
the top and bottom of the layer, or if there are some modules that can
automatically consider that the property extends to the next underlying
layer.
I think from what i understand, i will need to generate a data point for
each meter of elevation along the borehole axis, and possibly interpolate
each elevation separately or using a module that can do 3D interpolation
such as v.vol.rst. although i want to constrain the interpolation
horizontally, so I may need to interpolate each elevation separately
(manually or in batch mode).
alternatively, i could be able to do a query in grass at each elevation to
search for the property above along the Bh axis during the interpolation
process but this seems complicated. I can generate properties for each
elevations in Access in import into Grass.
Thanks
Francois
Le mar. 10 juil. 2018 à 21:59, Moritz Lennert <mlennert at club.worldonline.be>
a écrit :
> Hi François,
> On 10/07/18 04:40, Francois Chartier wrote:
> > Hi Moritz,
> > The idea is a bit novel. I am working with over 20000 Boreholes (BH)
> > with soil information (silt, sand, gravel, Tills, and everything in
> > between etc.). These are not distinct geological contacts with
> > recognizable stratigraphies that can be correlated, ex: this top of
> > gravel corresponds to this top of gravel in this BH etc. The model
> > domain is approximately 40 km by 40 km and extends from ground surface
> > (DEM) to top of bedrock (surface from geological survey), and thickness
> > varies from approx. 15 m to 100 m.
> > As it would take years to correlate all the soil contact elevations, I
> > am approaching the problem from a different angle. The dataset consists
> > of XYZ and Property (top of soil deposit) at each borehole location
> > (XY). Along the vertical axis of the borehole, there are multiple top
> > of soil deposits overlying on top of each other depending on the depth
> > of the BH and location.
> > In between each top of soil there are no data points in the database,
> > however, in the real world there is a soil property. Therefore if i am
> > interpolating only the top of soil data, the interpolation method will
> > do a gradual change between the top (n) of that soil deposit and its
> > bottom which is also the top of the next underlying soil deposit (n-1).
> > In order to avoid this, I would like to ensure that the 'weight' of that
> > soil deposit thickness in the interpolation is considered. Whether the
> > interpolation modules in Grass GIS can (first option)do this
> > interpolation by considering that the property extends to the next
> > underlying deposit,
> IIUC what you mean, r.to.rast3elev does exactly that: It does not do any
> interpolation. Each input map ('input' parameter) corresponds to a soil
> type. Each elevation map ('elevation' parameter) corresponds to either
> the top or the bottom level of that type. Using the -u or -l flag, you
> can ask r.to.rast3elev to fill the volume above or below your elevations
> with the value of the map.
> In other words, if you have
> r.mapcalc "soil1 = 1"
> r.mapcalc "soil2 = 2"
> r.mapcalc "soil3 = 3"
> and you have 2D elevation maps resulting from the interpolation of the
> top elevation of the respective soils: elev1, elev2, elev3
> You can run:
> r.to.rast3elev -l input=soil1,soil2,soil3 elevation=elev1,elev2,elev3
> output=soils_3D
> You should get something like this:
> -----------top elevation soil1-------
> 1111111111111111111111111111111111111
> -----------top elevation soil2-------
> 2222222222222222222222222222222222222
> -----------top elevation soil3-------
> 3333333333333333333333333333333333333
> Obviously with elevations varying in space.
> There are issues if you have inversions in the order of soil layers,
> i.e. if you have something like this:
> 111111111111112222222222222222
> 222222222222221111111111111111
> AFAIK, the only way to solve this is to cut up your area into tiles of
> homogeneous order.
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180711/0d7d4f45/attachment.html>
