[GRASS-user] calculate the volume of a DEM with r.volume
Helmut Kudrnovsky
hellik at web.de
Fri Jul 13 02:27:48 PDT 2018
[could you send plain text mails? as html mails aren't readable in the ML,
see:
http://lists.osgeo.org/pipermail/grass-user/2018-July/078772.html]
>As you can see, I have nothing at the end of the command...
tested here with
System Info
GRASS Version: 7.4.0
GRASS SVN revision: r72154
Build date: 2018-01-27
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
r.volume input=elevation at PERMANENT clump=geology_30m at PERMANENT
Volume report on data from <elevation at PERMANENT> using clumps on
<geology_30m at PERMANENT> raster map
Category Average Data # Cells Centroid Total
Number in clump Total in clump Easting Northing Volume
217 118.93 86288828 725562 635325.00 221535.00
8628882798.63
262 108.97 21650560 198684 638935.00 222495.00
2165056037.02
270 92.23 63578874 689373 642405.00 221485.00
6357887443.53
405 132.96 33732662 253710 631835.00 224095.00
3373266208.59
583 139.35 3011288 21609 630205.00 224665.00
301128821.55
720 124.30 599618 4824 634075.00 227995.00
59961816.06
766 132.43 936791 7074 631425.00 227845.00
93679120.08
862 118.31 7302317 61722 630505.00 218885.00
730231746.74
910 94.20 4235816 44964 639215.00 216365.00
423581613.11
921 135.22 1693985 12528 630755.00 215445.00
169398523.05
945 127.24 1145 9 630015.00 215015.00
114512.03
946 89.91 365748 4068 639085.00 215255.00
36574833.85
948 129.02 112632 873 630185.00 215115.00
11263181.57
Total Volume =
22351026655.81
(Fri Jul 13 11:20:20 2018) Befehl ausgeführt (0 Sek)
could you
[1] test with the NC sample data set in the r.volume manual:
https://grass.osgeo.org/grass74/manuals/r.volume.html
with the GUI and on the windows command console provided by winGRASS
[2] change the language/locale of winGRASS to en (= english)
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
