[GRASS-user] calculate the volume of a DEM with r.volume
marion-brunet at sfr.fr
Fri Jul 13 03:43:11 PDT 2018
<span style="font-family:arial,helvetica,sans-serif; font-size:12px"></span><span style="font-family:arial,helvetica,sans-serif; font-size:12px">(sorry for the html emails, hope this one is readable)<br>
<br>
I tried with the North Carolina dataset (in GRASS 7.4.0), I had those results: </span><br>
<br>
r.volume input=elevation at PERMANENT clump=geology_30m at PERMANENT <br>
Volume report on data from <elevation at PERMANENT> using clumps on <geology_30m at PERMANENT> raster map<br>
Category Average Data # Cells Centroid Total<br>
Number in clump Total in clump Easting Northing Volume<br>
-----------------------------------------------------------------------------<br>
217 120.27 99583 828 637785.00 220865.00 9958257.22<br>
262 119.65 2765729 23115 638485.00 220415.00 276572908.36<br>
270 104.79 586004 5592 639345.00 220305.00 58600408.47<br>
Total Volume = 345131574.05<br>
<br>
I tried it with the GUI and on the windows command console, and I have the exact same result.<br>
It is not the same result as you, or as on the r.volume manual, but I do have the "Total Volume" line.<br>
Do you think it can be
<div class="gl_quote" style="margin-top: 20px; padding-top: 5px;">De : "Helmut Kudrnovsky"<br>
A : grass-user at lists.osgeo.org<br>
Envoyé: vendredi 13 juillet 2018 11:27<br>
Objet : ***SPAM*** Re: [GRASS-user] calculate the volume of a DEM with r.volume<br>
<div class="gl_quoted">[could you send plain text mails? as html mails aren't readable in the ML, see: http://lists.osgeo.org/pipermail/grass-user/2018-July/078772.html] >As you can see, I have nothing at the end of the command... tested here with ---- System Info GRASS Version: 7.4.0 GRASS SVN revision: r72154 Build date: 2018-01-27 Build platform: x86_64-w64-mingw32 GDAL: 2.2.3 PROJ.4: 4.9.3 GEOS: 3.5.0 SQLite: 3.17.0 Python: 2.7.5 wxPython: 2.8.12.1 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W) ---- ---- r.volume input=elevation at PERMANENT clump=geology_30m at PERMANENT Volume report on data from using clumps on raster map Category Average Data # Cells Centroid Total Number in clump Total in clump Easting Northing Volume ----------------------------------------------------------------------------- 217 118.93 86288828 725562 635325.00 221535.00 8628882798.63 262 108.97 21650560 198684 638935.00 222495.00 2165056037.02 270 92.23 63578874 689373 642405.00 221485.00 6357887443.53 405 132.96 33732662 253710 631835.00 224095.00 3373266208.59 583 139.35 3011288 21609 630205.00 224665.00 301128821.55 720 124.30 599618 4824 634075.00 227995.00 59961816.06 766 132.43 936791 7074 631425.00 227845.00 93679120.08 862 118.31 7302317 61722 630505.00 218885.00 730231746.74 910 94.20 4235816 44964 639215.00 216365.00 423581613.11 921 135.22 1693985 12528 630755.00 215445.00 169398523.05 945 127.24 1145 9 630015.00 215015.00 114512.03 946 89.91 365748 4068 639085.00 215255.00 36574833.85 948 129.02 112632 873 630185.00 215115.00 11263181.57 ----------------------------------------------------------------------------- Total Volume = 22351026655.81 (Fri Jul 13 11:20:20 2018) Befehl ausgeführt (0 Sek) ---- could you [1] test with the NC sample data set in the r.volume manual: https://grass.osgeo.org/grass74/manuals/r.volume.html with the GUI and on the windows command console provided by winGRASS [2] change the language/locale of winGRASS to en (= english) ----- best regards Helmut -- Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html _______________________________________________ grass-user mailing list grass-user at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/grass-user</div>
<div class="gl_quoted"> </div>
</div>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180713/161cae59/attachment.html>
