[GRASS-user] script option
Frank David
frank.david at geophom.fr
Fri Jul 13 10:26:36 PDT 2018
Le 11/07/2018 à 09:31, Nikos Alexandris a écrit :
> * Frank David <frank.david at geophom.fr> [2018-07-10 15:44:51 +0200]:
>> Le 10/07/2018 à 12:25, Nikos Alexandris a écrit :
>>> * frank <frank.david at geophom.fr> [2018-07-10 08:05:29 +0200]:
>>>> Hi dear grass users,
>>>> I'm trying to get two field name of an attribute table (ctx_map) by
>>>> the options of the gui. But I can access only at the first one and
>>>> I don't find why...??. See my code below :
>>>> #%option G_OPT_V_MAP
>>>> #% key: ctx_map
>>>> #% description: vector data
>>>> #% required : yes
>>>> #% guidependency:layer,ctx_wf,ctx_wtg
>>>> #%end
>>>> #%option G_OPT_V_FIELD
>>>> #% key:ctx_layer
>>>> #% guidependency:ctx_wf,ctx_wtg
>>>> #%end
>>>> #%option G_OPT_DB_COLUMN
>>>> #% key:ctx_wf
>>>> #% description: wf name
>>>> #% required: yes
>>>> #%end
>>>> #% key:ctx_wtg
>>>> #% description: wtg name
>>>> #% required: yes
>>>> #%end
>>>> Thank you for your help.
>>>> Frank
>>> Dear Frank,
>> Hello Nikos,
>>> if you refer to the last two "column" options,
>>> how do you try to access these, in the script?
>>> Like,
>>> options['ctx_wf']
>>> options['ctx_wtg']
>> Absolutely
>>> Also, what .xml does
>>> x.ScriptName --interface-description
>>> generate?
>> There is no error on compilation, and help tab display Flags and
>> Parameters information, like (french accent are not well encoded):
>> Parameters:
>> obj_map=name [required]
>> Name of vector map
>> MH ou WTG projet
>> obj_layer=string
>> Layer number or name
>> Vector features can have category values in different layers. This
>> number determines which layer to use. When used with direct OGR
>> access this is the layer name.
>> Default: 1
>> obj_name=name [required]
>> Nom de l'objet
>> *ctx_map=name [required] **
>> **Name of vector map **
>> *Contexte éolien *
>> **ctx_layer=string **
>> **Layer number or name **
>> **Vector features can have category values in different layers. This
>> access this is the layer name. **
>> **Default: 1 **
>> **ctx_wf=name [required] **
>> *Nom du parc *
>> **ctx_wtg=name [required] **
>> *Identifiant éolienne
> Ah, and what does `x.ScriptName --ui` return?
> Maybe an encoding related issue? Related entries in trac:
> https://trac.osgeo.org/grass/search?q=encoding+french&noquickjump=1&changeset=on&milestone=on&ticket=on&wiki=on
> Nikos
Hello Nikos,
x.myscript --ui just launch the gui box.
I have found a trick to run the script. Actually I need one field from
on vector table and 2 fields from an other vector table. like that it
works :
#% label: MH ou WTG projet
#% required : yes
#% guidependency: layer,obj
#%end
#% guidependency: obj
#%end
#% key: obj
#% description: Nom de l'objet
#% required: yes
#%end
#% key: ctx_map
#% label: Contexte éolien
#% required : yes
#% guidependency:ctx_layer,ctx_wf,ctx_wtg
#%end
#% key:ctx_layer
#%end
#% key:ctx_wf
#% description: Nom du parc
#% required: yes
#%end
#% key:ctx_wtg
#% description: Identifiant éolienne
#% required: yes
#%end
But as soon as I try to name myself the first table by Key parameter
like #%key : obj_map and add key name at layer (like in the second part
of the code) It does not work anymore... It looks like the fisrt map is
automatically named "map" by the gui. I don't mind but I find this
strange. I'm sure there is a explanation,somewhere...
Cheers,
Frank
*Geophom*
327 rue de Vieille Cour 44521 OUDON
Tel +33(0)2 85 52 02 59 - Port +33(0)6 04 47 91 06
www.geophom.fr
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180713/8a270927/attachment.html>
