[GRASS-user] calculate the volume of a DEM with r.volume
Moritz Lennert mlennert at club.worldonline.be
Mon Jul 16 02:02:17 PDT 2018
On 15/07/18 13:52, marion-brunet at sfr.fr wrote:
> Hi,
> Thank you for the clarification on the clumps, it makes more sense for
> me now.‌
> However you said :
> "Ideally, the clump option of r.volume should be optional. You could file
> an enhancement wish on trac for that."
> But I don't really understand what you mean by "an enhancement wish on
> trac for that", could you explain it a bit more ?
Yes, sorry, I understand that this is not clear language for someone new
to the community. trac is the software we use for bug ticket management,
as technical wiki and it allows you to browse the source code [1].
Whenever you detect a bug, or you wish to see an enhancement to GRASS
GIS, you can file a ticket on trac. This gives a more solid existence to
you wish as bugs or wishes declared in messages sent to the mailing list
often get lost in the mass of mails.
In order to be able to file a ticket you need a OSGeo userid [2].
> I tried doing both r.volume and multiplying the sum by the cell size,
> and I have approximately the same results, but there a are some little
> differences. I think it is because, with the second method, I rounded up
> the results I had, because there were too many digits, so I might I lost
> some precision in my results.
That is quite possible. Have you tried without rounding ?
Moritz
[1] https://trac.osgeo.org/grass
[2] https://www.osgeo.org/community/getting-started-osgeo/osgeo_userid/
