[GRASS-user] r,in.gdal error when importing a jpeg2000 image
Markus Metz
markus.metz.giswork at gmail.com
Wed Jul 18 05:59:22 PDT 2018
On Wed, Jul 18, 2018 at 10:32 AM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi Users,
> Trying to import an 8.7gb (jpeg2000) image into Grass 7.4.1 64 bit. I get
the error below. Tested the image in another OS GIS package and it opens
without issue. Not sure why Grass wont import it.
The errors are coming from GDAL, not GRASS. The same error messages should
appear with GDAL tools that read the entire image, e.g. gdal_translate.
Markus M
> Thanks everyone!
> Paul Shapley
> (Wed Jul 18 09:19:16 2018)
> r.in.gdal -o input=J:\Spatial
Data\Aerial\APGB_received_20180416\aerial_25cm.jp2
output=aerial_25cm_master memory=3000
> Over-riding projection check
> Importing 3 raster bands...
> Importing raster map <aerial_25cm_master.red>...
> ERROR 1: Marker is not compliant with its position
> ERROR 1: opj_decode() failed
> ERROR 1: J:\Spatial
> Data\Aerial\APGB_received_20180416\aerial_25cm.jp2, band 1:
> IReadBlock failed at X offset 0, Y offset 0
> ERROR 1: GetBlockRef failed at X block offset 0, Y block
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> ERROR 1: J:\Spatial
> offset 0
> Please note that the data are left in inconsistent state and may be
corrupted
> (Wed Jul 18 09:19:40 2018) Command aborted (24 sec)
> Paul J. Shapley MSc CGeog (GIS) FRGS
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180718/3c22e0f9/attachment.html>
