[GRASS-user] 3D raster color coding
Francois Chartier
fra.chartier at gmail.com
Sat Jun 2 10:57:57 PDT 2018
how do you ensure that region is selected to the extent of the raster. I
think I already did this when making v.vol.rst.
Le sam. 2 juin 2018 à 13:56, Veronica Andreo <veroandreo at gmail.com> a
écrit :
> What about the region? Is it set to the extent of your raster?
> El sáb., 2 jun. 2018 19:52, Francois Chartier <fra.chartier at gmail.com>
> escribió:
>> i removed the 'r' and used elevation and bcyr as the color tables, see
>> below. Display window is blank.
>> to recap the steps:
>> 1 - i selected the Mapset and also tried Map that corresponds to the 3d
>> raster
>> 2 - then in Define tab, i only choose the Name of Color Table: bcyr, i
>> have not selected anything else,
>> 3 - then i just Run.
>> (Sat Jun 02 13:45:02 2018)
>> r3.colors map=BHALL_May24v2 at Toronto color=elevation
>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'elevation'
>> (Sat Jun 02 13:45:02 2018) Command finished (0 sec)
>> (Sat Jun 02 13:46:14 2018)
>> r3.colors map=BHALL_May24v2 at Toronto color=bcyr
>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bcyr'
>> (Sat Jun 02 13:46:15 2018) Command finished (0 sec)
>> Le sam. 2 juin 2018 à 09:01, Francois Chartier <fra.chartier at gmail.com>
>> a écrit :
>>> Is there any way to set the range for the color table?
>>> On Sat, Jun 2, 2018, 02:33 Veronica Andreo, <veroandreo at gmail.com>
>>> wrote:
>>>> Try removing -r from your command (unchecking the box in the GUI).
>>>> That flag is used to remove a color palette.
>>>> Best,
>>>> Vero
>>>> El sáb., 2 jun. 2018 3:48, Francois Chartier <fra.chartier at gmail.com>
>>>> escribió:
>>>>> Hi Veronica,
>>>>> something is odd. here are the steps - Display window is still blank
>>>>> and the 3D raster has data ranging from -8 to 34.
>>>>> Step 2 - set as viridis - according to manual this
>>>>> *result in command window*
>>>>> (Fri Jun 01 21:44:05 2018)
>>>>> r3.colors -r map=BHALL_May24v2 at Toronto color=viridis
>>>>> (Fri Jun 01 21:44:05 2018) Command finished (0 sec)
>>>>> *Display is still blank. *
>>>>> *Data is there*
>>>>> | Type of Map: raster_3d Number of Categories: 0
>>>>> | Data Type: FCELL
>>>>> | Rows: 90
>>>>> | Columns: 85
>>>>> | Depths: 307
>>>>> | Total Cells: 2348550
>>>>> | Total size: 3180868 Bytes
>>>>> | Number of tiles: 336
>>>>> | Mean tile size: 9466 Bytes
>>>>> | Tile size in memory: 30420 Bytes
>>>>> | Number of tiles in x, y and z: 6, 7, 8
>>>>> | Dimension of a tile in x, y, z: 15, 13, 39
>>>>> | Projection: UTM (zone 17)
>>>>> | N: 4870795 S: 4825715 Res: 500.88888889
>>>>> | E: 651669 W: 609204 Res: 499.58823529
>>>>> | T: 352 B: 45 Res: 1
>>>>> | Range of data: min = -8.99099445 max = 33.89262009
>>>>> | Data Source:
>>>>> | Data Description:
>>>>> | generated by v.vol.rst
>>>>> | Comments:
>>>>> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>>>>> tension=40. \ |
>>>>> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>>>>> zscale=1.\ |
>>>>> | 0 elevation="BHALL_May24v2"
>>>>> Le ven. 1 juin 2018 à 12:54, Francois Chartier <fra.chartier at gmail.com>
>>>>> a écrit :
>>>>>> Thanks, I'll check it out.
>>>>>> On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo at gmail.com>
>>>>>> wrote:
>>>>>>> Hello,
>>>>>>> That's probably because that palette is for integer values ranging
>>>>>>> from 0 to 360 [0]. Try with a relative one such as viridis or bcyr.
>>>>>>> HTH,
>>>>>>> Vero
>>>>>>> [0] https://grass.osgeo.org/grass74/manuals/r.colors.html
>>>>>>> El jue., 31 may. 2018 a las 3:18, Francois Chartier (<
>>>>>>> fra.chartier at gmail.com>) escribió:
>>>>>>>> Hi,
>>>>>>>> I have created a 3D raster from soil properties with about 70K
>>>>>>>> points, with a* lot of help from the mailing list i must say*.
>>>>>>>> from the copy of the metadata of the 3d raster (below) it would
>>>>>>>> confirm that the 3D raster worked and the grid is populated with data.
>>>>>>>> I have copied below the r3.colors and assigned 'aspectcolr' as a
>>>>>>>> trial. Unfortunately in the Display window nothing shows up, whether in 2D
>>>>>>>> or in 3D view. I do not know what i am doing incorrectly.
>>>>>>>> Once I am done and able to develop the 3D raster of the soil
>>>>>>>> properties, I will prepare a simple step by step for developing such a
>>>>>>>> raster which may be useful for others.
>>>>>>>> | Layer: BHALL_May24v2 at Toronto Date: Sun May 27
>>>>>>>> 16:43:46 2018 |
>>>>>>>> | Mapset: Toronto Login of Creator:
>>>>>>>> Francois Charti |
>>>>>>>> | Location: Toronto
>>>>>>>> | DataBase: C:\Users\Francois Chartier\Documents\grassdata
>>>>>>>> | Title: BHALL_May24v2
>>>>>>>> | Units: none
>>>>>>>> | Vertical unit: units
>>>>>>>> | Timestamp: none
>>>>>>>> | Data Type: FCELL
>>>>>>>> | Rows: 90
>>>>>>>> | Columns: 85
>>>>>>>> | Depths: 307
>>>>>>>> | T: 352 B: 45 Res: 1
>>>>>>>> | Data Source:
>>>>>>>> | Data Description:
>>>>>>>> | Comments:
>>>>>>>> tension=40. \ |
>>>>>>>> zscale=1.\ |
>>>>>>>> (Wed May 30 21:11:59 2018) Command finished (0 sec)
>>>>>>>> (Wed May 30 21:10:02 2018)
>>>>>>>> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
>>>>>>>> 'aspectcolr'
>>>>>>>> (Wed May 30 21:10:03 2018) Command finished (0 sec)
>>>>>>>> _______________________________________________
>>>>>>>> grass-user mailing list
>>>>>>>> grass-user at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180602/ca38fadd/attachment-0001.html>
