[GRASS-user] 3D raster color coding
Francois Chartier
fra.chartier at gmail.com
Sat Jun 2 11:05:08 PDT 2018
C:\Users\Francois Chartier>g.region -p
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4870795
south: 4825715
west: 609204
east: 651669
nsres: 500.88888889
ewres: 499.58823529
rows: 90
cols: 85
cells: 7650
metadata from 3d raster
Title: BHALL_May24v2 |
| Units: none
| Vertical unit: units
| Timestamp: none
| Type of Map: raster_3d Number of Categories: 0
| Data Type: FCELL
| Rows: 90
| Columns: 85
| Depths: 307
| Total Cells: 2348550
| Total size: 3180868 Bytes
| Number of tiles: 336
| Mean tile size: 9466 Bytes
| Tile size in memory: 30420 Bytes
| Number of tiles in x, y and z: 6, 7, 8
| Dimension of a tile in x, y, z: 15, 13, 39
| Projection: UTM (zone 17)
| N: 4870795 S: 4825715 Res: 500.88888889
| E: 651669 W: 609204 Res: 499.58823529
| T: 352 B: 45 Res: 1
| Range of data: min = -8.99099445 max = 33.89262009
| Data Source:
| Data Description:
| generated by v.vol.rst
| Comments:
| v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat" tension=40.
| smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
zscale=1.\ |
| 0 elevation="BHALL_May24v2"
Le sam. 2 juin 2018 à 14:01, Veronica Andreo <veroandreo at gmail.com> a
écrit :
> g.region manual page:
> https://grass.osgeo.org/grass74/manuals/g.region.html
> # print current region info
> g.region -p
> # set to a raster 3d
> g.region raster_3d=nameofyourmap
> El sáb., 2 jun. 2018 19:58, Francois Chartier <fra.chartier at gmail.com>
> escribió:
>> how do you ensure that region is selected to the extent of the raster. I
>> think I already did this when making v.vol.rst.
>> Le sam. 2 juin 2018 à 13:56, Veronica Andreo <veroandreo at gmail.com> a
>> écrit :
>>> What about the region? Is it set to the extent of your raster?
>>> El sáb., 2 jun. 2018 19:52, Francois Chartier <fra.chartier at gmail.com>
>>> escribió:
>>>> i removed the 'r' and used elevation and bcyr as the color tables, see
>>>> below. Display window is blank.
>>>> to recap the steps:
>>>> 1 - i selected the Mapset and also tried Map that corresponds to the
>>>> 3d raster
>>>> 2 - then in Define tab, i only choose the Name of Color Table: bcyr, i
>>>> have not selected anything else,
>>>> 3 - then i just Run.
>>>> (Sat Jun 02 13:45:02 2018)
>>>> r3.colors map=BHALL_May24v2 at Toronto color=elevation
>>>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'elevation'
>>>> (Sat Jun 02 13:45:02 2018) Command finished (0 sec)
>>>> (Sat Jun 02 13:46:14 2018)
>>>> r3.colors map=BHALL_May24v2 at Toronto color=bcyr
>>>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bcyr'
>>>> (Sat Jun 02 13:46:15 2018) Command finished (0 sec)
>>>> Le sam. 2 juin 2018 à 09:01, Francois Chartier <fra.chartier at gmail.com>
>>>> a écrit :
>>>>> Is there any way to set the range for the color table?
>>>>> On Sat, Jun 2, 2018, 02:33 Veronica Andreo, <veroandreo at gmail.com>
>>>>> wrote:
>>>>>> Try removing -r from your command (unchecking the box in the GUI).
>>>>>> That flag is used to remove a color palette.
>>>>>> Best,
>>>>>> Vero
>>>>>> El sáb., 2 jun. 2018 3:48, Francois Chartier <fra.chartier at gmail.com>
>>>>>> escribió:
>>>>>>> Hi Veronica,
>>>>>>> something is odd. here are the steps - Display window is still
>>>>>>> blank and the 3D raster has data ranging from -8 to 34.
>>>>>>> Step 2 - set as viridis - according to manual this
>>>>>>> *result in command window*
>>>>>>> (Fri Jun 01 21:44:05 2018)
>>>>>>> r3.colors -r map=BHALL_May24v2 at Toronto color=viridis
>>>>>>> (Fri Jun 01 21:44:05 2018) Command finished (0 sec)
>>>>>>> *Display is still blank. *
>>>>>>> *Data is there*
>>>>>>> | Data Type: FCELL
>>>>>>> | Rows: 90
>>>>>>> | Columns: 85
>>>>>>> | Depths: 307
>>>>>>> | T: 352 B: 45 Res: 1
>>>>>>> | Data Source:
>>>>>>> | Data Description:
>>>>>>> | Comments:
>>>>>>> tension=40. \ |
>>>>>>> zscale=1.\ |
>>>>>>> Le ven. 1 juin 2018 à 12:54, Francois Chartier <
>>>>>>> fra.chartier at gmail.com> a écrit :
>>>>>>>> Thanks, I'll check it out.
>>>>>>>> On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hello,
>>>>>>>>> That's probably because that palette is for integer values ranging
>>>>>>>>> from 0 to 360 [0]. Try with a relative one such as viridis or bcyr.
>>>>>>>>> HTH,
>>>>>>>>> Vero
>>>>>>>>> [0] https://grass.osgeo.org/grass74/manuals/r.colors.html
>>>>>>>>> El jue., 31 may. 2018 a las 3:18, Francois Chartier (<
>>>>>>>>> fra.chartier at gmail.com>) escribió:
>>>>>>>>>> Hi,
>>>>>>>>>> I have created a 3D raster from soil properties with about 70K
>>>>>>>>>> points, with a* lot of help from the mailing list i must say*.
>>>>>>>>>> from the copy of the metadata of the 3d raster (below) it would
>>>>>>>>>> confirm that the 3D raster worked and the grid is populated with data.
>>>>>>>>>> I have copied below the r3.colors and assigned 'aspectcolr' as
>>>>>>>>>> a trial. Unfortunately in the Display window nothing shows up, whether in
>>>>>>>>>> 2D or in 3D view. I do not know what i am doing incorrectly.
>>>>>>>>>> Once I am done and able to develop the 3D raster of the soil
>>>>>>>>>> properties, I will prepare a simple step by step for developing such a
>>>>>>>>>> raster which may be useful for others.
>>>>>>>>>> | Layer: BHALL_May24v2 at Toronto Date: Sun May 27
>>>>>>>>>> 16:43:46 2018 |
>>>>>>>>>> | Mapset: Toronto Login of Creator:
>>>>>>>>>> Francois Charti |
>>>>>>>>>> | Location: Toronto
>>>>>>>>>> | DataBase: C:\Users\Francois Chartier\Documents\grassdata
>>>>>>>>>> | Units: none
>>>>>>>>>> | Timestamp: none
>>>>>>>>>> | Data Type: FCELL
>>>>>>>>>> | Rows: 90
>>>>>>>>>> | Columns: 85
>>>>>>>>>> | Depths: 307
>>>>>>>>>> | T: 352 B: 45 Res: 1
>>>>>>>>>> | Data Source:
>>>>>>>>>> | Data Description:
>>>>>>>>>> | Comments:
>>>>>>>>>> tension=40. \ |
>>>>>>>>>> zscale=1.\ |
>>>>>>>>>> (Wed May 30 21:11:59 2018) Command finished (0 sec)
>>>>>>>>>> (Wed May 30 21:10:02 2018)
>>>>>>>>>> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
>>>>>>>>>> 'aspectcolr'
>>>>>>>>>> (Wed May 30 21:10:03 2018) Command finished (0 sec)
>>>>>>>>>> _______________________________________________
>>>>>>>>>> grass-user mailing list
>>>>>>>>>> grass-user at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180602/73250d86/attachment-0001.html>
