[GRASS-user] v.class.mlR Error
Moritz Lennert
mlennert at club.worldonline.be
Wed Jun 6 00:05:29 PDT 2018
On 04/06/18 15:42, Jamille Haarloo wrote:
> It did not work out from another station, but I tried today from the
> same computer.
> I first reinstalled the module.
> This is the command output:
> Running R now. Following output is R output.
> Traceback (most recent call last):
> File "C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
> pts/v.class.mlR.py <http://v.class.mlR.py>", line 632, in <module>
> main()
> pts/v.class.mlR.py <http://v.class.mlR.py>", line 569, in main
> subprocess.check_call(['Rscript', r_commands],
> stderr=subprocess.STDOUT, )
> File "C:\Program Files\GRASS GIS
> 7.4.0\Python27\lib\subprocess.py", line 537, in check_call
> retcode = call(*popenargs, **kwargs)
> 7.4.0\Python27\lib\subprocess.py", line 524, in call
> return Popen(*popenargs, **kwargs).wait()
> 7.4.0\Python27\lib\subprocess.py", line 711, in __init__
> errread, errwrite)
> 7.4.0\Python27\lib\subprocess.py", line 948, in
> _execute_child
> startupinfo)
> WindowsError: [Error 2] The system cannot find the file
> specified
I still have the feeling that the system cannot find Rscript.
Can you open the GRASS terminal window and type 'Rscript' to see if it
can be found ?
Just to be sure: you do have R installed ?
> Error in atexit._run_exitfuncs:
> 7.4.0\Python27\lib\atexit.py", line 24, in _run_exitfuncs
> func(*targs, **kargs)
> pts/v.class.mlR.py <http://v.class.mlR.py>", line 236, in cleanup
> gscript.try_remove(model_output_csv)
> NameError: global name 'model_output_csv' is not defined
> Error in sys.exitfunc:
This NameError is a consequence of the earlier error, but anyhow I just
corrected it in r72773.
Moritz
