[GRASS-user] i.maxlik yellow map
Moritz Lennert
mlennert at club.worldonline.be
Thu Jun 7 04:36:41 PDT 2018
On 07/06/18 11:00, Paul Shapley wrote:
> Hi Users,
> I am re-posting this to see if anyone else may have some suggestions. My
> thanks to Veronica who suggested checking 'g.region' but this appears to
> be fine. I've also tried the same on Grass 7.2.2/7.4 and nightly but all
> produce the same result.
> signature file content:-
> #Bare_peat
> 2667621
> 60.4424 75.4845 87.2587
> 716.802
> 831.829 1086.7
> 869.829 1105.97 1179.92
> 0 0 0
> Original message:-
> I have created a signature file in the g.gui.iclass (supervised
> classification module) and it looks correct in 'preview' and when i
> inspected the 'sig' file. When the signature is applied using 'i.maxlik'
> the result is a solid yellow colour as a layer. What could have gone wrong?
Do you only have one class ? Then it is normal that all pixels will be
in the same class. You could ask i.maxlik to output the reject map and
then define a threshold in that map as a mask to show those areas whose
probability of being in the class is sufficiently high.
Moritz
