[GRASS-user] 3D raster color coding
Francois Chartier fra.chartier at gmail.com
Sun Jun 10 12:46:52 PDT 2018
 I have pasted below the colors files for the 3d raster.  the screen
capture shows that the data is there as i am showing the wireframe around
the data.  the r3.color is set to bgyr.  therefore, i do not see how come
the interpolated data does not show up in the display.
r3.colors map=BHALL_May24v2 at Toronto color=bgyr
Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bgyr'
color table - the data is associated with a color as per below.
% -8.9909944534301758 33.892620086669922
-8.9909944534301758:0:191:191 -0.41427154541015626:0:255:0
-0.41427154541015626:0:255:0 8.1624513626098629:255:255:0
16.739174270629881:255:127:0 25.315897178649902:191:127:63
25.315897178649902:191:127:63 33.892620086669922:200
8.1624513626098629:255:255:0 16.739174270629881:255:127:0
Metadata of 3d raster. - same range of data as color table.
ype of Map:  raster_3d            Number of Categories: 0               |
 |   Data Type:    FCELL
 |   Rows:         90
 |   Columns:      85
 |   Depths:       307
 |   Total Cells:  2348550
 |   Total size:           3180868 Bytes
 |   Number of tiles:      336
 |   Mean tile size:       9466 Bytes
 |   Tile size in memory:  30420 Bytes
 |   Number of tiles in x, y and  z:   6, 7, 8
 |   Dimension of a tile in x, y, z:   15, 13, 39
 |        Projection: UTM (zone 17)
 |            N:    4870795    S:    4825715   Res: 500.88888889
 |            E:     651669    W:     609204   Res: 499.58823529
 |            T:        352    B:         45   Res:     1
 |   Range of data:   min = -8.99099445 max = 33.89262009
 |   Data Source:
 |   Data Description:
 |    generated by v.vol.rst
 |   Comments:
 |    v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat" tension=40.
 |    smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
zscale=1.\   |
 |    0 elevation="BHALL_May24v2"
Le sam. 2 juin 2018 à 15:37, Helmut Kudrnovsky <hellik at web.de> a écrit :
> >Unfortunately in the Display window nothing shows up, whether in 2D or in
> 3D
> view.  I do not know what i >am doing incorrectly.
> see https://trac.osgeo.org/grass/ticket/3571
> please add your findings there.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180610/782d6875/attachment-0001.html>
Name: screencapture june10.gif
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180610/782d6875/attachment-0001.gif>
