[GRASS-user] problem
hindo kush
hindokush12 at gmail.com
Sat Jun 16 02:47:51 PDT 2018
All,
While calculating Net Radiation i have to run the r.sun module and i did
exactly what it was in the manual but the problem is this that i don't get
any output any hint!!!
(Sat Jun 16 12:39:45 2018)
r.sun elevation=Dem at PERMANENT aspect=aspec at PERMANENT slope=slp at PERMANENT
albedo=Albedo at PERMANENT lat=latmp at PERMANENT long=longmp at PERMANENT
incidout=IRdAnM1 beam_rad=BIrdM1 diff_rad=DIrdM1 refl_rad=GrIrdM1
glob_rad=GIrdM1 day=207 time=6
Number of threads <1>
Mode 1: instantaneous solar incidence angle & irradiance using a set local
time
Using Linke constant: 3.000000
Using albedo map <Albedo at PERMANENT>
Using slope map <slp at PERMANENT>
Using aspect map <aspec at PERMANENT>
(Sat Jun 16 12:39:53 2018) Command finished (8 sec)
GRASS 4.1
windows 64bit
16Gp Ram
kindly see the attached picture as well
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180616/738abb01/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180616/738abb01/attachment-0001.jpg>
