[GRASS-user] i.nightlights.intercalibration, Problem with running code
Nikos Alexandris
nik at nikosalexandris.net
Tue Jun 19 21:33:14 PDT 2018
Dear Gabriel,
I realise, now, that if you try to run something with $() or backticks
in a input box, in the (G)UI, it won't work.
Try, please, directly the command line (or the Console in the GUI):
i.nightlights.intercalibration image=$(g.list rast pattern=F* sep=,) suffix=c model=elvidge2014
The following will _not_ work:
i.nightlights.intercalibration image= image=$(g.list rast pattern=F* sep=,) suffix=suffix=c model=elvidge2014
Nikos
ps- Kind request, please keep posting on the list.
* Nikos Alexandris <nik at nikosalexandris.net> [2018-06-20 04:07:27 +0200]:
>Dear Gabriel,
>try this:
>Details: the command `g.list` is not actually run, I think.
>Use the proper syntax, which is to enclose the command with a
>"$(g.list type=raster)".
>In my repository, and in the the manual there is still some demo
>command using backticks, like:
>i.nightlights.intercalibration image=`g.list rast pattern=F* sep=,`
>which is the old style. Better the new style, i.e.:
>If you don't do this, the module will "think" that the option `image`
>is fed with only:
>image=g.list
>and the rest of the line will be treated as extra arguments.
>Nikos
>----- Original Message -----
>From:
> "Gabriel Cotlier" <gabiklm01 at gmail.com>
>To:
><grass-user at lists.osgeo.org>
>Cc:
>Sent:
>Tue, 19 Jun 2018 12:44:33 -0300
>Subject:
> Problem with running _i.nightlights.intercalibration
>_
>_ for the
>_Elvidge(2014) model-coefficients.
> Steps I have followed:
> 1.I have imported the following layers:
> (Tue Jun 19 12:29:20
>2018)
> g.list
>type=raster
> F101992
> F101993
> F101994
> F121994
> F121995
> F121996
> F121997
> F121998
> F121999
> F141997
> F141998
> F141999
> F142000
> F142001
> F142002
> F142003
> F152000
> F152001
> F152002
> F152003
> F152004
> F152005
> F152006
> F152007
> F162004
> F162005
> F162006
> F162007
> F162008
> F162009
> F182010
> F182011
> F182012
> (Tue Jun 19 12:29:21 2018) Command finished (0
>sec)
> 2. I have run the code on the dialog box of
>__ :
>_
> _
>_
> 3. I got the following error message:
> (Tue Jun 19 12:31:26 2018)
> i.nightlights.intercalibration image=g.list type=raster
> |i Inter-satellite calibration of DMSP-OLS Nighttime Stable Lights
> WARNING: Operating on current region
> |> Calibrating average visible Digital Number values
> WARNING: No data base element files found
> Traceback (most recent call last):
> File "C:UsersGabrielAppDataRoamingGRASS7addons/scrip
> ts/i.nightlights.intercalibration.py [1]", line 525, in <module>
> sys.exit(main())
> ts/i.nightlights.intercalibration.py [2]", line 340, in main
> model_parameters = retrieve_model_parameters(Model,
> *args)
> ts/i.nightlights.intercalibration.py [3]", line 242, in
> model = model_class(*args, **kwargs)
> File "C:UsersGabrielAppDataRoamingGRASS7addonsetci
> .nightlights.intercalibrationintercalibration_models.py",
> line 155, in __init__
> CalibrationModel.__init__(self, author, satellite, year)
> line 43, in __init__
> year=self.year)
> line 63, in verify_year
> available_years = COEFFICIENTS[author][satellite].keys()
> KeyError: 'g.l'
> (Tue Jun 19 12:31:27 2018) Command finished (1 sec)
> Thanks a lot for your help
> and
>assistance
> Best regards,
> Gabriel
>Links:
>[1] http://i.nightlights.intercalibration.py
>[2] http://i.nightlights.intercalibration.py
>[3] http://i.nightlights.intercalibration.py
>_______________________________________________
>grass-user mailing list
>https://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180620/afb51c57/attachment-0001.sig>
