[GRASS-user] r3.in.xyz
Moritz Lennert
mlennert at club.worldonline.be
Thu Jun 28 00:40:51 PDT 2018
On 27/06/18 16:32, Francois Chartier wrote:
> So therefore, my approach of generating a soil property at each
> elevation and interpolating is a correct approach.
> Is there a way that i can constrain the interpolation horizontally.
Not sure what you mean by constraining the interpolation horizontally.
You can create a 2D elevation map by interpolating all your height
information of layer 1 (for example using v.surf.rst). Then you create a
second elevation map interpolating the layer 2 height information, etc.
Moritz
> I.
> Cant remember the module name i am using but i am generating the 3d
> raster from the 3d data points directly.
> On Tue, Jun 26, 2018, 23:38 Moritz Lennert,
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> On 27/06/18 03:59, Francois Chartier wrote:
> > Hi,
> > I am working with a data set that consists of borehole logs with
> a Top
> > of a layer (layer 1) and the top of the underlying layer (layer 2)
> > (which is also the bottom of the overlying layer 1). Everything in
> > between the elevation of top of layer 1 and top of layer 2
> correspond to
> > a Layer 1 property.
> > The thickness of Layer 1 varies and this layer may not exist
> everywhere
> > (pinches out). Above the Layer the property is different; in other
> > words the property only starts below the Top of layer 1 until the
> > underlying Top of the next layer.
> > Not sure of the capabilities of the interpolation in Grass and
> working
> > with a very large data set (i cannot link every top of layers
> together),
> > my first approach was to create a each Layer property for every
> > elevation slice along each Borehole axis, interpolating soil
> properties
> > at every elevation between Boreholes.
> > I read on another forum that r3.in.xyz <http://r3.in.xyz>
> <http://r3.in.xyz> can
> > interpolate in 3D without a Property at every elevation slice,
> > * while respecting the condition that above the Top of the layer 2,
> > the property corresponds to the Overlying top layer 1, and
> > * that the property is continuous until the next underlying
> layer 3 -
> > can someone confirm this?
> > To provide a bit of background, borehole data bases, identify the
> top of
> > layer as encountered when drilling downwards, and provide the
> elevation
> > of the next layer (pick); in between the soil property is the same,
> > however there is no data points. When interpolating, while there
> is no
> > data point in between the two geological picks, the property should
> > still have weight in the interpolation process.
> I don't think r3.in.xyz <http://r3.in.xyz> is what you need. This
> module aggregates 3D
> point data into voxels.
> You probably want to use something like r.to.rast3. This would mean
> interpolating each layer separately into 2D elevation maps and then
> assemble them into 3D using r.to.rast3.
> Moritz
