[GRASS-user] v.out.postgis
    Moritz Lennert
    mlennert at club.worldonline.be
    Thu Jun 28 04:40:24 PDT 2018
On 28/06/18 09:59, Paul Shapley wrote:
> Hi,
> I am trying to export a vector map to PostGIS. Has anyone come across
> the 'Unable to describe table' error? I suspect my config could be wrong.
> v.out.postgis --overwrite
> input=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct at PERMANENT
> output=PG:dbname=webgis
> output_layer=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct
> options=FID=cat, GEOMETRY_NAME=wkb_geometry, SPATIAL_INDEX=YES,
> PRIMARY_KEY=YES
> DBMI-PostgreSQL driver error:
> select * from grass_gis.APGB_aerial_2_i_segment_drained_peat
> _with_exposed_haggs_vct where 1 = 0
> ERROR:  relation "grass_gis.apgb_aerial_2_i_segment_drained_
> peat_with_exposed_haggs_vct" does not exist
> LINE 1: select * from
> grass_gis.APGB_aerial_2_i_segment_drained_peat...
> *ERROR: Unable to describe table*
> <grass_gis.APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct>
It looks like it is trying to read the input attrubute table from
postgresql (schema grass_gis). Do you use PostgreSQL as attribute table
backend ? Could you provide the output of db.connect -p in that mapset ?
Moritz
