[GRASS-user] v.clean: recommend tools and sequence
Helmut Kudrnovsky
hellik at web.de
Fri Jun 29 10:10:11 PDT 2018
Rich Shepard wrote
> On Fri, 29 Jun 2018, Markus Metz wrote:
>> After import with v.in.ogr, overlapping parts have a category value set
>> in
>> layer 2. If you want to get rid off all overlapping parts, check with
>> v.category op=report if any centroids still have a category value in
>> layer
>> 2. Sometimes these areas can be cleaned away with v.clean tool=rmarea,
>> sometimes manual editing with the vector digitizer is needed.
> Markus,
> Followed your advice and there are still the same warnings with the
> same
> values. Is there a way for me to determine where in this large map of
> publicly-owned forests in the state the 107 overlapping polygons are
> located?
> Regards,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
d.vect layer=2 .... ?
the manuals are a good source where to look.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
