[GRASS-user] Query regarding r.horizon in GRASS GIS 7.2.2 as a standalone
Helmut Kudrnovsky
hellik at web.de
Wed Mar 7 05:12:33 PST 2018
Johnn Wani wrote
> Dear sir,
> Thanks for your response.
> I tried with NC sample dataset and it worked fine.
> Regards
> John
> On Wed, Mar 7, 2018 at 4:23 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> Johnn Wani wrote
>> > Dear GRASS GIS users,
>> > I am a student from India. I am using *GRASS GIS 7.2.2 as a standalone*
>> in
>> > Windows 10 operating system.
>> > My aim is to use r.horizon module to calculate horizon at a point in my
>> > study area and save it to a .csv file. As I run the following command
>> in
>> > the console window on GRASS GIS:
>> > r.horizon -d --overwrite elevation=n34_e077_1arc_v3 at PERMANENT
>> direction=90
>> > step=22.5 coordinates=741302,3793829 file=C:\Users\user\horizon.csv
>> > But I am receiving an error message as attached herewith. Earlier also
>> I
>> > got the same error message but at that time it was due to non-alignment
>> of
>> > my DEM.
>> > This time my DEM is aligned, here is the output of g.region -p command:
>> > g.region -p
>> > projection: 3 (Latitude-Longitude)
>> > zone: 0
>> > datum: wgs84
>> > ellipsoid: wgs84
>> > north: 35:00:00.5N
>> > south: 33:59:59.5N
>> > west: 76:59:59.5E
>> > east: 78:00:00.5E
>> > nsres: 0:00:01
>> > ewres: 0:00:01
>> > rows: 3601
>> > cols: 3601
>> > cells: 12967201
>> > (Wed Mar 07 15:15:14 2018) Command finished (0 sec)
>> have you tried the example with the NC sample data set mentioned in the
>> manual?
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>> grass-user mailing list
> grass-user at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/grass
Could you set
g.gisenv set="DEBUG=3"
before you run the module on your own data and report the debug output
best regards
Helmut
