[GRASS-user] Install GRASS stable and experimental in parallel
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Tue Mar 13 01:30:37 PDT 2018
Hi Moritz,
(warming this post up again ...).
I see your point!
And I am aware, that dependencies might be changed in development versions. QGIS has some nightly builds e.g. with ubuntugis dependencies.
Maybe snap could be useful? There does not seem to be a snap for GRASS yet:
https://snapcraft.io/search?q=grass
If you guys think this is of interest, I could have a look at it in Bonn (and maybe join forces with QGIS project if the relevant people for the QGIS snap [1,2] are in Bonn too).
I would also consider contributing to packaging, but I have no experience with that. So, maybe Martin (as we are on Ubuntu), we can have a short chat in Bonn to see if I can be of help there...
Looking forward to seeing you in Bonn!
Cheers
Stefan
1: https://github.com/Wollac/snap-qgis
2: https://github.com/elopio/QGIS/blob/snapcraft/snapcraft.yaml
-----Original Message-----
From: Moritz Lennert [mailto:mlennert at club.worldonline.be]
Sent: torsdag 14. desember 2017 15.59
> I think Stefan means distribution packages.
> Theoretically this is possible. One could create a specific "grass-trunk" package which is packaged in a way to not conflict with the official stable grass version.
> However, I think most distribution packagers are already very busy just handling the stable packages. The difficulty with creating such a grass-trunk package would be that it would have to be repackaged regularly (daily),
> but this means that whoever used it would have to have exactly the same versions of dependecy packages installed on their machine as on the package build machine.
> And then, which distribution and which version of a distribution should we make packages for ?
> In summary: if you are willing to create such a package against a clearly defined version of a distribution than this would be great, but I don't think you can count on either the core developers of GRASS, nor the packagers of different distributions for doing this.
> Moritz
