[GRASS-user] v.clean Failed to build area
Heidi Ochis
hiho at ctmap.com
Wed May 2 07:28:21 PDT 2018
My best guess is each line is creating a close polyline - which is why
the islands do not have duplicate points.
We wrote a program to run though each line, identify the location each
line begins to backtrack, then break and remove the remaining points.
Unfortunately, some of the contours do not start and stop at the edge
of the DEM, but rather have beginning nodes many points within the
DEM. Anything on the "back side" of the node is dropped.
Heidi Ochis
Computer Terrain Mapping, Inc
420 21st Ave, Suite 114
Longmont, CO 80501
303-444-1670
hiho at ctmap.com
On May 2, 2018, at 12:32 AM, Markus Metz wrote:
Hi Peter,
On Tue, May 1, 2018 at 11:33 PM, Peter Tittmann <ptittmann at gmail.com>
wrote:
> Hi Markus,
> I'm ashamed to admit that I hacked my way into fixing this problem
by exporting the vector dataset using `v.out.ogr` to a geopackage then
importing it. The cleaning tools in v.in.ogr seemed to solve my
problem..
the reason why this works is that these incorrect boundaries are not
exported. When re-importing, you will get a clean vector but some of
the original areas are gone. If you still want to find out what went
wrong where, you would need to find out where these incorrect
boundaries first appeared in the processing steps of your original
vector.
Markus M
> Very clumsy, but it worked.
> Thank you!
> Peter
> On Fri, Apr 27, 2018 at 11:51 AM, Markus Metz <markus.metz.giswork at gmail.com
> wrote:
>> [ please keep this on the GRASS mailing list ]
>> On Fri, Apr 27, 2018 at 6:43 PM, Peter Tittmann
<ptittmann at gmail.com> wrote:
>> > Hi Markus,
>> > grass72 -v
>> > GRASS GIS 7.2.2
>> This is already the latest 7.2 release. You might try GRASS 7.4.
>> > i will try to figure out how to get the latest release up and
running. If you have any suggestions for fixing the boundaries, that
would be great.
>> If upgrading to the latest GRASS 7.4 release does not help, I
would need the data for testing to find out why removing small areas
fails. If the vector has been imported from an external datasource
without modification of the geometries inside GRASS, this version
would be preferable. Otherwise the history of
plot_pa_with_lidar at project_area would be helpful (v.info -h).
>> Markus M
>> > Peter
>> > On Thu, Apr 26, 2018 at 11:19 PM, Markus Metz <markus.metz.giswork at gmail.com
> wrote:
>> >> On Fri, Apr 27, 2018 at 1:37 AM, Peter Tittmann <ptittmann at gmail.com
> wrote:
>> >> > Hi,
>> >> > I am attempting to use the `rmarea` tool in v.clean with a
threshold of ~ 1000 sq meters.
>> >> > I am getting a rather cryptic message ‘Failed to build area’.
>> >> > > v.clean -c --overwrite --verbose
input=plot_pa_with_lidar at project_area output=plot_pa_rmarea
tool=rmarea threshold=1017.2
>> >> > Tool: Threshold
>> >> > Remove small areas: 1017.2
>> >> > WARNING: Vector map <plot_pa_rmarea> already exists and will
be overwritten
>> >> > Using native format
>> >> > Copying features...
>> >> > 100%
>> >> > Rebuilding parts of topology...
>> >> > Building topology for vector map
<plot_pa_rmarea at project_area>...
>> >> > Registering primitives...
>> >> > 1720636 primitives registered
>> >> > 3439992 vertices registered
>> >> > Building areas...
>> >> > WARNING: Area of size = 0.0 ignored
>> >> > 100%
>> >> > 499671 areas built
>> >> > 6004 isles built
>> >> > Attaching islands...
>> >> > 100%
>> >> > Attaching centroids...
>> >> > 100%
>> >> > Topology was built
>> >> > Number of nodes: 728615
>> >> > Number of primitives: 1720636
>> >> > Number of points: 0
>> >> > Number of lines: 0
>> >> > Number of boundaries: 1222309
>> >> > Number of centroids: 498327
>> >> > Number of areas: 499671
>> >> > Number of isles: 6004
>> >> > WARNING: Number of incorrect boundaries: 9
>> >> > WARNING: Number of duplicate centroids: 14
>> >> > Tool: Remove small areas
>> >> > ERROR: Failed to build new area
>> >> I guess the problem are these 9 incorrect boundaries. Which
GRASS version are you using? Can you try again with the latest release
in case you are not using the latest release?
>> >> Markus M
grass-user mailing list
grass-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180502/96a1b10c/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180502/96a1b10c/attachment-0001.jpg>
