[GRASS-user] flow accumulation (GRASS and Esri ArcGIS)
Anna Petrášová kratochanna at gmail.com
Wed May 2 11:29:51 PDT 2018
On Wed, May 2, 2018 at 2:21 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, May 2, 2018 at 7:13 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> one of my colleague is dealing with flow accumulation calculation in
>> GRASS, and comparing results with Esri ArcGIS (builtin Flow
>> Accumulation [1]). Tool in ArcGIS to me knowledge uses D8, so we run
>> r.watershed with -s flag and also -a flag to avoid negative values.
>> Resultant values are very different.
>> * Esri ArcGIS (range: 0 - 20741)
>> * r.watershed -s (range: -34068 - 5697)
>> * r.watershed -sa (1 - 34068)
> I'd suggest to look at the univariate statistics first (r.univar -e)
> and compare that instead of min/max only.
Also, r.watershed uses least-cost path, unlike the arcmap tool. Did
you fill the depressions before running the arcmap tool?
Anna
> markusN
>> Do you have idea why results are so different? Thanks for any pointers
>> in advance! Martin
>> [1] http://desktop.arcgis.com/en/arcmap/10.5/tools/spatial-analyst-toolbox/flow-accumulation.htm
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Markus Neteler, PhD
> http://www.mundialis.de - free data with free software
> http://grass.osgeo.org
> http://courses.neteler.org/blog
