[GRASS-user] Vector to 2D Raster
Francois Chartier
fra.chartier at gmail.com
Sat May 12 12:33:07 PDT 2018
v.info message
(Sat May 12 15:29:10 2018)
v.info map=BHMat1All at Toronto
| Mapset: Toronto |
| Database: C:\Users\ \Documents\grassdata |
| Title: |
| Map scale: 1:1 |
| Name of creator: |
| Organization: |
| Source date: Sun May 06 14:53:16 2018 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 76887 Number of centroids: 0 |
| Number of lines: 0 Number of boundaries: 0 |
| Number of areas: 0 Number of islands: 0 |
| Number of faces: 0 Number of kernels: 0 |
| Number of volumes: 0 Number of holes: 0 |
| Map is 3D: Yes |
| Number of dblinks: 0 |
| Projection: UTM (zone 17) |
| N: 4870795 S: 4825715 |
| E: 651669 W: 609204 |
| B: 45 T: 352 |
| Digitization threshold: 0 |
| Comment: |
(Sat May 12 15:29:10 2018) Command finished (0 sec)
And
v.info -c map=BHMat1All at Toronto
ERROR: Database connection for map <BHMat1All at Toronto> is not defined in DB
file
C:\Users\ >
It would seem that it needs to be connected to DB?
Regards,
Sent from Mail for Windows 10
Sent: May 12, 2018 3:26 PM
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Vector to 2D Raster
>v.vol.rst input=BHMat1All at Toronto dmin=0.5 elevation=may11
>ERROR: Unable to get layer info for vector map
>(Sat May 12 14:46:07 2018) Command finished (0 sec)
could you post here the result of
and
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180512/86cc71b8/attachment.html>
