[GRASS-user] Vector to 2D Raster
Francois Chartier fra.chartier at gmail.com
Sat May 12 14:22:07 PDT 2018
Not enough disk space for temp file... too much data i guess for my computer.  Is there a possibility to write temp files to an external hard drive?
Sent from Mail for Windows 10
Sent: May 12, 2018 4:23 PM
To: Helmut Kudrnovsky; grass-user at lists.osgeo.org
Subject: RE: [GRASS-user] Vector to 2D Raster
Bare with me.  I guessed the issue was for the region was not defined with the 3d region. So I ran g.region and define the region in NS, EW, and Top and bottom.  Now V.vol.rst is running....crushing numbers.
Sent: May 12, 2018 3:57 PM
I have reimported the data set and have linked it to a new db as i assume this is the issue.
I rerun v.vol.rst and i have to define ‘cat’ as the name of col that contains the w-values attribute to interpolate. These match the attribute i want to interpolate from the db.
Now the issue is the data is not in the region....zero points in the region.
Sent: May 12, 2018 3:43 PM
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Vector to 2D Raster
>v.info -c map=BHMat1All at Toronto
>ERROR: Database connection for map <BHMat1All at Toronto> is not defined in DB
>       file
just before you mentioned:
"I have 4 columns, X, Y, Z, Property (numerical)."
have you tried the example of the v.vol.rst-manual?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
Virus-free. www.avast.com
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180512/f74c9519/attachment.html>
