[GRASS-user] Redefining computational region for vector overlay
HernĂ¡n De Angelis
dhdeangelis at comhem.se
Sun May 13 13:31:03 PDT 2018
On 2018-05-13 21:29, Markus Metz wrote:
> ou could try to replace
> 3. v.clip
> with
> 3.1. v.select to select only those areas overlapping with the current
> buffer
> 3.2 v.overlay of the selected areas with the current buffer which
> should now take only seconds
> Markus M
That made a *very* serious improvement in performance!
Now processing ~2.5 points per minute (30 in 12 minutes). From the
previous 1 every 8 minutes with v.clip this change makes a ~20x
Thanks Markus for the suggestion and thanks Moritz for your kind help!
/H.
