[GRASS-user] Grass GIS Temporary files too large
Francois Chartier
fra.chartier at gmail.com
Mon May 21 11:19:32 PDT 2018
I am trying to run a 3D interpolation with 70k points. When running
V.Vol.RST, the simulation runs out of memory for the Temp File on my
computer. I have 78 gb of space on my laptop and running a solid state
hard drive so relatively small to begin with.
Should I run the simulation from an external hard drive. I have 1 TB
available external drive available, or
are there some settings that I can change in Grass or V.Vol.RST to make it
work with the Temp file?
If I do run from an external drive, do i have to move all the grass files
to the external drive for the temp file to be saved there or is there a
setting where i can change the saving location?
I have been looking at the link below which is supposed to explain how to
manage large datasets; however, i am too computer/grass illeterate to
understand this.
https://grass.osgeo.org/grass72/manuals/variables.html
Thanks
F.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180521/db8fafd1/attachment.html>
