[GRASS-user] Grass GIS Temporary files too large
Francois Chartier
fra.chartier at gmail.com
Wed May 23 04:00:38 PDT 2018
Simulation ran all night with the 70 k points and still at 10%. I reran to
get the error message but still not there yet.
2018-05-22 13:55 GMT-04:00 Markus Neteler <neteler at osgeo.org>:
> On Mon, May 21, 2018 at 8:19 PM, Francois Chartier
> <fra.chartier at gmail.com> wrote:
> > Hi,
> > I am trying to run a 3D interpolation with 70k points. When running
> > V.Vol.RST, the simulation runs out of memory for the Temp File on my
> > computer.
> Could you please post the error message?
> thanks
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/eabec268/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/eabec268/attachment-0001.png>
(Tue May 22 20:35:17 2018)
v.vol.rst input=BHMat1All_May12 at Toronto
WARNING: Missing column name
ERROR: Column type of wcolumn is not supported (must be integer or double)
(Tue May 22 20:35:17 2018) Command finished (0 sec)
(Tue May 22 20:35:28 2018)
v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat
25 records selected from table
Processing all selected output files will require 0 bytes of disk space for temp files
WARNING: Points are more dense than specified 'DMIN'--ignored 47799 points (remain 29088)
WARNING: Unable to create <(null)> raster map without cross_input raster map being specified
WARNING:
Overshoot -- increase in tension suggested.
Overshoot occurs at (3324,8871,270) cell
The w-value is -3.500526, wmin is 0.000000,wmax is 34.000000
