[GRASS-user] v vol rst super slow
Francois Chartier
fra.chartier at gmail.com
Wed May 23 18:02:18 PDT 2018
which output do you select to have a 3D Raster?
2018-05-23 15:32 GMT-04:00 Markus Metz <markus.metz.giswork at gmail.com>:
> On Wed, May 23, 2018 at 1:40 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > On Wed, May 23, 2018 at 1:18 PM, Sören Gebbert
> > <soerengebbert at googlemail.com> wrote:
> > > Hi,
> > > your region settings are interesting.
> > > Do you really need a resolution of 5m in x,y plane and 1m in z
> direction?
> > > As a result you have 23,507,876,616 voxel to compute, but only 76887
> > > points for interpolation.
> > > I would suggest you reduce the resolution of your region
> > > significantly, at least to test the interpolation settings.
> > Indeed, at least to get a complete run.
> > > Best regards
> > > Soeren
> > > 2018-05-23 13:09 GMT+02:00 Francois Chartier <fra.chartier at gmail.com>:
> > >> see below
> > >> g.region -3p
> > >> projection: 1 (UTM)
> > >> cells: 76572888
> > >> cells3: 23507876616
> > >> v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
> > >> 25 records selected from table
> > >> Processing all selected output files will require 0 bytes of disk
> space for
> > >> temp files
> These 0 bytes are caused by integer overflow, easy to fix.
> > >> WARNING: Unable to create <(null)> raster map without cross_input
> raster map
> > >> being specified
> > that comes from
> > vector/v.vol.rst/main.c" line 640
> > To be studied...
> The reason is that no output has been specified.
> Markus M
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/4556fe54/attachment.html>
