[GRASS-user] v.class.mlR Error
Jamille Haarloo
j.r.haarloo at gmail.com
Tue May 29 12:38:59 PDT 2018
Dear GRASS GIS community,
I just started working with Grass to try some object-based analysis. I do
not have much experience with programming, but learning bits on the go.
The segmentation test with uspo appears to have been ok, but I am
struggling with the next step. I was suspecting the training vector created
in QGIS wasn't meeting proper standards, but I could not find a
straightforward Grass module for labeling segments/ creating a training set
file.
Hopefully someone can help me out.
Command output:
(Tue May 29 14:18:32 2018)
v.class.mlR -i --overwrite training_map=Training_Ben2 at haarlooj_Ben_Test
segments_file=C:\Users\haarlooj\Documents\CELOS\Stats_Training_Ben_test
separator=comma
raster_segments_map=best_myregion1_at_haarlooj_Ben_Test_rank1 at haarlooj_Ben_Test
train_class_column=code output_class_column=vote output_prob_column=prob
classifiers=svmRadial,rf,C5.0 folds=5 partitions=10 tunelength=10
weighting_modes=smv,qbwwv weighting_metric=accuracy
classification_results=X:\Projecten\Land-use Planning Marowijne\GIS en
RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_test_classifier-Results
accuracy_file=X:\Projecten\Land-use Planning Marowijne\GIS en
RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_Test_accuracy
model_details=X:\Projecten\Land-use Planning Marowijne\GIS en
RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_Test_ClassifierDetails
bw_plot_file=X:\Projecten\Land-use Planning Marowijne\GIS en
RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_test_classifier_performance
r_script_file=X:\Projecten\Land-use Planning Marowijne\GIS en
RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_test_R_script
processes=3
Running R now. Following output is R output.
File "C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
pts/v.class.mlR.py", line 633, in <module>
main()
pts/v.class.mlR.py", line 570, in main
subprocess.check_call(['Rscript', r_commands],
stderr=subprocess.STDOUT, )
File "C:\Program Files\GRASS GIS
7.4.0\Python27\lib\subprocess.py", line 537, in check_call
retcode = call(*popenargs, **kwargs)
7.4.0\Python27\lib\subprocess.py", line 524, in call
return Popen(*popenargs, **kwargs).wait()
7.4.0\Python27\lib\subprocess.py", line 711, in __init__
errread, errwrite)
7.4.0\Python27\lib\subprocess.py", line 948, in
_execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file
specified
(Tue May 29 14:18:33 2018) Command finished (0 sec)
Best,
Jamille
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180529/c9b2c3e6/attachment.html>
