[GRASS-user] Running grass in virtualbox with shared folders
knussear
knussear at mac.com
Tue May 29 16:10:46 PDT 2018
Hi all
I'm running grass7 in virtual box (tried both ubuntu mate and mint linux)
and trying to open a location/mapset located on a mounted shared folder.
Write permissions appear to work in the file browser, but I get an error
(pasted below) trying to start the grass gui. Any thoughts on how to fix?
THX
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.3 (NixonDemo):~ > ERROR: MAPSET lidartst - permission denied
File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 37, in <module>
from lmgr.frame import GMFrame
File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/usr/lib/grass70/gui/wxpython/lmgr/layertree.py", line 37, in
<module>
from mapdisp.frame import MapFrame
File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 64, in
<module>
class MapFrame(SingleMapFrame):
File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 70, in
MapFrame
page = None, Map = Map(), auimgr = None, name = 'MapWindow', **kwargs):
File "/usr/lib/grass70/gui/wxpython/core/render.py", line 414, in __init__
self.mapfile = grass.tempfile(create = False) + '.ppm'
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 736, in
tempfile
return read_command("g.tempfile", flags=flags, pid=os.getpid()).strip()
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 445, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 312, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.tempfile', '-d',
'pid=2280'] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
