[GRASS-user] Help needed with stream channel slope
    Thomas Adams
    tea3rd at gmail.com
    Wed May 30 14:09:50 PDT 2018
Hi Micha,
Thank you -- I looked at this previously, but I think I misunderstood what
it did. I've tried r.stream.slope and it sure looks like it's doing what I
need. Thank you for encouraging me to re-visit it!
Best,
Tom
On Wed, May 30, 2018 at 3:34 PM, Micha Silver <tsvibar at gmail.com> wrote:
> Hi Tom:
> On 05/30/2018 05:32 PM, Thomas Adams wrote:
> Hi all,
> I have written an involved script (which I run automatically), in part,
> calling r.basin to get the stream channel slope (preferably at the basin
> outlet). For all basin outlet locations, r.basin defines the watershed
> correctly, but for about 10% of the locations the *_parameters.csv file is
> not created and I get errors:
> Have you looked at the addon r.stream.slope ??
> https://grasswiki.osgeo.org/wiki/AddOns/GRASS7/raster#r.stream.slope
> Hypsometric | quantiles
> 360 | 0.025
> 358 | 0.05
> 356 | 0.1
> 351 | 0.25
> 341 | 0.5
> 330 | 0.75
> 321 | 0.9
> 316 | 0.975
> Done!
> ../src/gtk/dcclient.cpp(250): assert "Assert failure" failed in
> wxFreePoolGC(): Wrong GC
>  100%
> Tot. cells 1886.0
> Tot. area 188600.0
> Max distance 771.033539
> Traceback (most recent call last):
>   File "/home/teaiii/.grass7/addons/scripts/r.width.funct", line 132, in
> <module>
>     sys.exit(main())
>   File "/home/teaiii/.grass7/addons/scripts/r.width.funct", line 87, in
> main
>     prc[4,0] , prc[4,1] = findint(kl,0.5) , 0.5
>   File "/home/teaiii/.grass7/addons/scripts/r.width.funct", line 125, in
> findint
>     z1, z2, f1, f2 = kl[int(Xf[0])][0], kl[int(Xf[0]-1)][0],
> kl[int(Xf[0])][1], kl[int(Xf[0]-1)][1]
> TypeError: only length-1 arrays can be converted to Python scalars
> An ERROR occurred running r.basin
> Please check for error messages above or try with another pairs of outlet
> coordinates
> Removing region definition <original>
> grep: mjk473_dem_parameters.csv: No such file or directory
> Channel average slope (percent):
> Drainage Area (sq km):
> I know the basin boundary is generated correctly because I generate a map
> automatically.
> So, the above is a problem; I have sent a lot of time trying to understand
> where I'm going wrong. I just re-built GRASS 7.4.0 and that had no effect
> in correcting the problem.
> r.basin generates waaay more than I need. Is there a simpler way the get
> the average main channel slope? I've looked through the available modules
> and can not find another way to do this. I just need a single value...
> Best regards,
> Tom
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180530/df56d513/attachment.html>
