[GRASS-user] v.class.mlR Error
Moritz Lennert
mlennert at club.worldonline.be
Thu May 31 04:15:24 PDT 2018
On 31/05/18 12:16, Helmut Kudrnovsky wrote:
>> In file(file, ifelse(append, "a", "w")) :
>> cannot open file '.gscript_tmp_model_output_2392.csv': Permission denied
> in the R script:
> resultsdf$prob_smv <- vote$V2
> write.csv(resultsdf, '.gscript_tmp_model_output_2392.csv', row.names=FALSE,
> quote=FALSE)
> write.csv(resultsdf, 'D:\temp\vclassr\class.txt', row.names=FALSE,
> quote=FALSE)
> AFAIR in windows and python, you need to specify the temp file e.g. by
> python's tempfile functions that it can be found later in the process.
Thanks for testing !
You're right. I don't remember why I coded this in that manner. It might
have been to ensure the .csv and .csvt suffix needed for db.in.ogr.
Could you try with below patch ?
Moritz
Index: v.class.mlR.py
--- v.class.mlR.py (révision 72333)
+++ v.class.mlR.py (copie de travail)
@@ -233,8 +233,8 @@
gscript.try_remove(feature_vars)
if trainmap:
gscript.try_remove(training_vars)
- gscript.try_remove(model_output)
- gscript.try_remove(model_output_desc)
+ gscript.try_remove(model_output_csv)
+ gscript.try_remove(model_output_csvt)
gscript.try_remove(r_commands)
if reclass_files:
for reclass_file in reclass_files.itervalues():
@@ -251,8 +251,8 @@
global trainmap
global feature_vars
global training_vars
- global model_output
- global model_output_desc
+ global model_output_csv
+ global model_output_csvt
global temptable
global r_commands
global reclass_files
@@ -483,8 +483,9 @@
r_file.write("\n")
if allmap and not flags['f']:
- model_output = '.gscript_tmp_model_output_%d.csv' % os.getpid()
- write_string = "write.csv(resultsdf, '%s'," % model_output
+ model_output = gscript.tempfile()
+ model_output_csv = model_output + '.csv'
+ write_string = "write.csv(resultsdf, '%s'," % model_output_csv
write_string += " row.names=FALSE, quote=FALSE)"
r_file.write(write_string)
r_file.write("\n")
@@ -575,10 +576,10 @@
- model_output_desc = model_output + 't'
+ model_output_csvt = model_output + '.csvt'
temptable = 'classif_tmp_table_%d' % os.getpid()
- f = open(model_output_desc, 'w')
+ f = open(model_output_csvt, 'w')
header_string = '"Integer"'
if flags['i']:
for classifier in classifiers:
@@ -595,7 +596,7 @@
gscript.message("Loading results into attribute table")
gscript.run_command('db.in.ogr',
- input_=model_output,
+ input_=model_output_csv,
output=temptable,
overwrite=True,
quiet=True)
