[GRASS-user] v.class.mlR Error
Helmut Kudrnovsky
hellik at web.de
Thu May 31 13:14:39 PDT 2018
Moritz Lennert wrote
>>>> Yes, obviously. Sorry for that.
>>> no problem.
>>> patch applied:
>>> v.class.mlR --verbose segments_map=lsat7_segs_stats
>>> training_map=training
>>> train_class_colum=class processes=3
>>> Running R now. Following output is R output.
>>> Loading required package: caret
>>> Loading required package: lattice
>>> Loading required package: ggplot2
>>> Loading required package: foreach
>>> Loading required package: iterators
>>> Loading required package: parallel
>>> Warning message:
>>> In nominalTrainWorkflow(x = x, y = y, wts = weights, info = trainInfo,
>>> There were missing values in resampled performance measures.
>>> Error: '\g' is an unrecognized escape in character string starting
>>> "'D:\g"
>>> "'D:\g"
>>> there seems to be a path issue with shlashes
>> added a g.message about the temporary file:
>> v.class.mlR --verbose segments_map=lsat7_segs_stats training_map=training
>> temporary file:
>> D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\10300.3.csv
>> AFAIR R in windows needs slashes, e.g.
>>> getwd()
>> [1] "C:/Users/myuser/Documents"
> Right.
> Would replacing tempfile() with tempfile().replace('\\', '/') in line
> 486 help ?
> ISTR that there was a function for this somewhere, but can't find it in
> a quick search.
> Attached the again entire patch, but with the above change.
yes, looks good now:
temporary file: D:/grassdata/nc_spm_08_grass7/user1/.tmp/unknown/13920.3.csv
Warning message:
In nominalTrainWorkflow(x = x, y = y, wts = weights, info = trainInfo, :
Finished running R.
Loading results into attribute table
(Thu May 31 22:12:30 2018) Command finished (2 min 45 sec)
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
