[GRASS-user] v.class.mlR Error
Helmut Kudrnovsky
hellik at web.de
Thu May 31 13:43:58 PDT 2018
>This said, if I understand the OP's message, the issue was in finding
>Rscript in MS Windows.
looking at the original report:
Running R now. Following output is R output.
File "C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
pts/v.class.mlR.py", line 633, in <module>
main()
pts/v.class.mlR.py", line 570, in main
subprocess.check_call(['Rscript', r_commands],
stderr=subprocess.STDOUT, )
File "C:\Program Files\GRASS GIS
7.4.0\Python27\lib\subprocess.py", line 537, in check_call
retcode = call(*popenargs, **kwargs)
7.4.0\Python27\lib\subprocess.py", line 524, in call
return Popen(*popenargs, **kwargs).wait()
7.4.0\Python27\lib\subprocess.py", line 711, in __init__
errread, errwrite)
7.4.0\Python27\lib\subprocess.py", line 948, in
_execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file
specified
yes, it seems it's the issue finding the Rscript.
>Do you have any recommendation on this ?
the tempfile and the path to it has to be properly build, acknowledging to
operating system characteristics; and, as in this case, considering the
peculiarity of involved 3rd party software.
e.g.
# path in windows
D:\temp\vclassr
vs.
# path in R in windows
D:/temp/vclassr
but don't be confused [1] [2], windows operating system also understands
D:/temp/vclassr, e.g. you can cd in the command line or open it in the
windows explorer ;-D ...
[1]
https://bytes.com/topic/python/answers/23123-when-did-windows-start-accepting-forward-slash-path-separator
[2]
https://www.howtogeek.com/181774/why-windows-uses-backslashes-and-everything-else-uses-forward-slashes/
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
