[GRASS-user] Migrating to new RDBMS [DONE]
Rich Shepard
rshepard at appl-ecosys.com
Thu Nov 1 08:25:30 PDT 2018
On Tue, 30 Oct 2018, Rich Shepard wrote:
> Trying to run db.copy to add attribute tables to the database (except for
> one that is already present) using a script with commands like this:
Markus M./Moritz:
All fixed now. There was an issue with the postgres upgrade from 9.x to
10.x (a long time ago) that did not appear until I tried connecting to a
database with grass. Took the rest of yesterday to fix broken symlinks and
this morning I upgraded from 10.3 to 10.5 (the upgrade to 11.0 can wait a
bit). Running 'db.test test1' in the latest 7.7.svn release required me to
add another host line in pg_hba.conf to allow access from all hosts on the
office network. Now everything's working:
> db.test test1
Using DB driver: pg
CREATE TABLE grass_test1 (i1 INTEGER, d1 DOUBLE PRECISION, c1 VARCHAR(20))
EXECUTE: OK
INSERT INTO grass_test1 VALUES ( 1, 123.456, 'abcd' )
EXECUTE: OK
INSERT INTO grass_test1 VALUES ( 2, null, 'xxx' )
EXECUTE: OK
SELECT * FROM grass_test1
EXECUTE: OK
RESULT: OK
SELECT c1 FROM grass_test1 WHERE d1 < 500 / 2 AND i1 <> 2 AND c1 LIKE '%bc%'
EXECUTE: OK
RESULT: OK
INSERT INTO grass_test1 VALUES ( 3, 0.0, '_\''_' )
EXECUTE: OK
ALTER TABLE grass_test1 ADD COLUMN i2 INTEGER
EXECUTE: OK
UPDATE grass_test1 SET d1 = 18.6, i2 = 987 WHERE i1 = 2
EXECUTE: OK
EXECUTE: OK
2d1
< 3|0|_\\'_|
3a3
> 3|0|_\'_|
ERROR: RESULT: ******** ERROR ********
DROP TABLE grass_test1
EXECUTE: OK
Had I not started to migrate my grass project databases to postgres I
would not have exposed the broken links (which did not stop psql from
working at the bash prompt for some reason).
Thank you both for your patient help,
Rich
