[GRASS-user] partial vector copy to smaller territory
Frank David frank.david at geophom.fr
Fri Nov 2 03:57:58 PDT 2018
Le 31/10/2018 à 20:57, Markus Metz a écrit :
> Hi Frank,
> On Wed, Oct 31, 2018 at 1:39 PM Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> wrote:
> > Hello Vero,
> > Thanks for your reply. It took almost one hour to extract my area (I
> guess because of topology). I do the same with Qgis from a shape in
> less than 10 minutes (but with several operations)... it's may be a
> bad idea to have a so heavy vector map in Grass...
> this kind of operation could be much faster in latest GRASS 7.4 than
> in any previous versions. Which GRASS version are you using?
Hello Markus,
I'm using 7.4.1 on debian9
But my grass db folder  is on a small server (Synology NAS), so may be
the network makes slow down the operation ?
Cheers,
Frank
> Markus M
> > Cheers,
> > Frank
> > Le 31/10/2018 à 11:26, Veronica Andreo a écrit :
> > Check v.extract or v.clip
> > Cheers,
> > Vero
> > El mié., 31 oct. 2018 7:20, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> escribió:
> >> Hello,
> >> What is the best and fast way to make a copy of a part of vector map
> >> (national) to get a smaller territory ? (partial copy).
> >> Thank you for your advice !
> >> Frank
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> >> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181102/40730657/attachment.html>
