[GRASS-user] v.colors usage [UPDATE]
Rich Shepard rshepard at appl-ecosys.com
Tue Nov 6 05:57:13 PST 2018
On Tue, 6 Nov 2018, st_kiefer at web.de wrote:
> Are there any entries in the table with bin_col is empty, i.e. null? I am
> not sure in this context, but I know from other cases that database driver
> failed in recognizing the datatype of a field while checking the first
> dataset in the table and the field was not set (i.e. null).
Stefan,
   No. There are only 82 rows in the table and the update command applied to
all rows, grouped first by 'site_nbr', then by the range of values in the
'howmany' column.
   I just checked (again) and every row has an entry for each column. Thanks
for the thought,
Best regards,
Rich
