[GRASS-user] ps.map read
Frank David frank.david at geophom.fr
Wed Nov 7 09:28:09 PST 2018
Hello all,
If I use <read> instruction inside my psmap file the command > ps.map
input=myfile.psmap output=myfile.ps does not work and the exit message is :
enter 'help' for help, 'end' when done, 'exit' to quit
But if I execute inside a shell loop, like > ls 01*.psmap |while read
fic;do ps.map input="${fic}" output="${fic%.*}.ps" --overwrite;done it
works! But I cannot run multiple ps.map with ls *.psmap. The error
message is :
ERREUR :myfile.psmap : illegal request
If I comment <read> instruction with # inside my psmap. everything is
working.
I have put my <read> just before the last <end> instruction. The read
file contains only a v.points layer.
Using a <read> is very powerfull, but ps.map in a shell loop is also
very usefull... to be able to do both would be ideal !
Thanks for your tricks if any
Cheers,
Frank
