[GRASS-user] Script for idw cross validation
Moritz Lennert mlennert at club.worldonline.be
Wed Nov 14 06:13:28 PST 2018
Hi Francesco,
On 13/11/18 05:57, francesco sapienza wrote:
> Hello! i'm trying to validate my IDW model for field values of pH (and
> other parameters) using the following:
> |# Partition sample points in 4 groups Module("v.kcv", map="pHsr",
> npartitions=4, column="part")|
> |Module("v.extract", flags="r", input="pHsr", output="pHcalibration",
> where="part=1")
 > Module("v.extract", input="pHsr", output="pHvalidation",
> where="part=1")|
You probably want to change your part=1 to something else in one of
these calls.
> |Module("v.surf.idw", input="pHcalibration", column="pH_values",
> npoints=12, power=2, output="pH_CAL_idw")|
> |Module("v.what.rast", map="pHvalidation", raster="pHsr",
> column="actual") Module("v.what.rast", map="pHvalidation",
> raster="pH_CAL_idw", column="Estimated")|
> Things work pretty good so far, i obtained a vector with the actual
> values and the estimated ones, the next step would be to evaluate the
> root mean square error for this routine.
Calculating something like the RMSE is actually quite easy, with no need
to use any SQL:
- Create a new column squared error, type double precision, with
v.db.addcolum
- Fill it using v.db.update using qcol="(estimated - actual)*(estimated
- actual)"
- Extract aggregated stats on that column using v.univar
- calculate the square root of the mean value to get RMSE
(You could also just get the mean of the absolute values of a column
containing simply (estimated - actual).)
> (Eventually i also want to loop
> the idw estimation for different set of Validation and Calibration groups).
> *So far i haven't used the script but instead i used the GUI interface
> for every single comand (v.kcv, v.extract, v.surf.idw and v.what.rast).*
> For the following section i wanted to use a script but i have trouble
> working it, as stats is 'not defined'.
> |sqlstat = "SELECT actual,estimated FROM pHvalidation" stats =
> Module("db.select", flags="c", sql=sqlstat, stdout_=PIPE).outputs.stdout
> stats = stats.replace("\n", "|")[:-1].split("|") stats =
> (np.asarray([float(x) for x in stats], dtype="float").
> reshape(len(stats)/2, 2))|
> rsme=np.sqrt(np.mean(np.diff(stats,axis=1)**2))
> I tried to run the GUI for db.select specifing in the sql SELECT= SELECT
> actual,estimated FROM pHvalidation".
> I obtained in the output of the GUI the right selected values, but i
> don't know how to procede calculating the RMSE value, when i try to run
> the script above, stats stay as 'not defined'.
I don't think you're using Module as expected. Please read [1]. AFAIR,
Modules.outputs is a dictionary of the modules' output parameters, not
the output of the module run.
Moritz
[1] https://grass.osgeo.org/grass74/manuals/libpython/pygrass_modules.html
