[GRASS-user] v.vol.rst - DMIN and Segment Size
Francois Chartier
fra.chartier at gmail.com
Wed Nov 14 18:06:32 PST 2018
So i rerun v.vol.rst with new g.region -p3
C:\>g.region -p3
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4862000
south: 4825700
west: 609200
east: 651700
top: 250.00000000
bottom: 50.00000000
nsres: 10
nsres3: 504.16666667
ewres: 10
ewres3: 500
tbres: 1
rows: 3630
rows3: 72
cols: 4250
cols3: 85
depths: 200
cells: 15427500
cells3: 1224000
V.VOL.RST run (below) with increasing DMIN, from 0.5 to 200. finally worked
with 200 m of min spacing. as you can see the majority of the points are
excluded.
I am using 180k points over a 40 km 40 km domain.
I have not set any smoothing parameters. also using the default tension
parameters and as data points are very close vertically (every m or less)
Thanks
(Wed Nov 14 20:50:41 2018)
v.vol.rst input=geotechNov8 at Toronto wcolumn=dbl_2 segmax=10 npmin=20
npmax=100 dmin=0.5 elevation=geotechnov8nov14
188692 records selected from table
WARNING: Some points outside of region -- will ignore...
ERROR: Points are too concentrated -- please increase DMIN
(Wed Nov 14 20:50:50 2018) Command finished (8 sec)
(Wed Nov 14 20:51:08 2018)
npmax=100 dmin=5 elevation=geotechnov8nov14
(Wed Nov 14 20:51:17 2018) Command finished (8 sec)
(Wed Nov 14 20:51:25 2018)
npmax=100 dmin=20 elevation=geotechnov8nov14
(Wed Nov 14 20:51:34 2018) Command finished (8 sec)
(Wed Nov 14 20:51:46 2018)
npmax=100 dmin=50 elevation=geotechnov8nov14
(Wed Nov 14 20:51:59 2018) Command finished (12 sec)
(Wed Nov 14 20:52:11 2018)
npmax=100 dmin=70 elevation=geotechnov8nov14
(Wed Nov 14 20:52:20 2018) Command finished (8 sec)
(Wed Nov 14 20:55:19 2018)
npmax=100 dmin=100 elevation=geotechnov8nov14
(Wed Nov 14 20:55:28 2018) Command finished (8 sec)
(Wed Nov 14 20:55:46 2018)
npmax=100 dmin=200 elevation=geotechnov8nov14
Processing all selected output files will require 24480 bytes of disk space
for temp files
WARNING: There are points outside specified 2D/3D region--ignored 3533
points (total points: 188692)
WARNING: Points are more dense than specified 'DMIN'--ignored 175580 points
(remain 13112)
WARNING: Unable to create <(null)> raster map without cross_input raster
map being specified
Finished interpolating
3D raster map <geotechnov8nov14> created
The number of points in vector map is 188692
The number of points outside of 2D/3D region 3533
The number of points used (after reduction) is 9579
(Wed Nov 14 20:55:58 2018) Command finished (12 sec)
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Le mer. 14 nov. 2018 à 20:40, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> good point. i created the 3d raster before. see g.region -p3 below.
> I will rerun v.vol.rst with the higher 3d g.region resolution, and keep
> increasing the dmin until it runs.
> C:\>g.region -p3
> projection: 1 (UTM)
> zone: 17
> datum: nad83
> ellipsoid: grs80
> north: 4862000
> south: 4825700
> west: 609200
> east: 651700
> top: 250.00000000
> bottom: 50.00000000
> nsres: 10
> ewres: 10
> ewres3: 500
> tbres: 1
> rows: 3630
> rows3: 72
> cols: 4250
> cols3: 85
> depths: 200
> cells: 15427500
> cells3: 1224000
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virus-free.
> www.avast.com
> <#m_3960299417046487252_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> Le mer. 14 nov. 2018 à 09:38, Moritz Lennert <mlennert at club.worldonline.be>
> a écrit :
>> On 14/11/18 01:28, Francois Chartier wrote:
>> > Hi,
>> > v.vol.rst starts working when npmin is 100 m or more. I dont believe
>> > that this algorythm only works with data points spaced by 100 m that
>> > does not make sense. is there a max total number for a dataset? is it
>> > because i have too few rows and columns?
>> > see metadata below. i also showed a lower dmin of 0.9. g.region is
>> > printed at the end of the email
>> Your g.region output does not correspond to the region that was set when
>> you ran v.vol.rst as the map created has a resolution of 500 in x and y
>> direction, but your region says 10.
>> Could you provide the output of g.region -p3 to also get the 3D settings ?
>> I don't have an exact idea, but the map you created has a resolution of
>> 500 x 500 x 176, so maybe if you have a point per meter this just means
>> that the number of points you have per target pixel is much too high.
>> Maybe you need to think about the appropriate 3D region first and make
>> sure to set that before running v.vol.rst ?
>> Moritz
>> > | Type of Map: raster_3d Number of Categories: 0
>> > | Data Type: FCELL
>> > | Rows: 90
>> > | Columns: 85
>> > | Depths: 2
>> > | Total Cells: 15300
>> > | Total size: 48229 Bytes
>> > | Number of tiles: 4
>> > | Mean tile size: 12057 Bytes
>> > | Tile size in memory: 15480 Bytes
>> > | Number of tiles in x, y and z: 2, 2, 1
>> > | Dimension of a tile in x, y, z: 43, 45, 2
>> > | Projection: UTM (zone 17)
>> > | N: 4870782 S: 4825713 Res: 500.76666667
>> > | E: 651697 W: 609201 Res: 499.95294118
>> > | T: 352 B: 0 Res: 176
>> > | Range of data: min = -1.17721057 max = 89.22615051
>> > | Data Source:
>> > | Data Description:
>> > | generated by v.vol.rst
>> > | Comments:
>> > | v.vol.rst --overwrite input="geotechNov8 at Toronto"
>> wcolumn="dbl_2"
>> > te\ |
>> > | nsion=40. smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=100
>> > wscale=1\ |
>> > | .0 zscale=1.0 elevation="geotechnov8"
>> > (Tue Nov 13 19:18:12 2018) Command finished (0 sec)
>> > *i have also tried with low dmin of 0.9 m:*
>> > (Tue Nov 13 19:22:49 2018)
>> > v.vol.rst --overwrite input=geotechNov8 at Toronto wcolumn=dbl_2 npmin=60
>> > npmax=100 dmin=0.9 elevation=geotechnov13
>> > (Tue Nov 13 19:23:00 2018) Command finished (10 sec)
>> > METADATA of Vector points
>> > Thu Nov 08 06:06:56 2018 |
>> > | Timestamp (first layer): none
>> > | Map format: native
>> > | Type of map: vector (level: 2)
>> > | Number of points: 188692 Number of centroids: 0
>> > | Number of lines: 0 Number of boundaries: 0
>> > | Number of areas: 0 Number of islands: 0
>> > | Number of faces: 0 Number of kernels: 0
>> > | Number of volumes: 0 Number of holes: 0
>> > | Map is 3D: Yes
>> > | Number of dblinks: 1
>> > | E: 651697 W: 609201
>> > | B: 0 T: 352
>> > | Digitization threshold: 0
>> > | Comment:
>> > (Tue Nov 13 19:25:30 2018) Command finished (0 sec)
>> > g.region - p
>> > projection: 1 (UTM)
>> > zone: 17
>> > datum: nad83
>> > ellipsoid: grs80
>> > north: 4862000
>> > south: 4825700
>> > west: 609200
>> > east: 651700
>> > nsres: 10
>> > ewres: 10
>> > rows: 3630
>> > cols: 4250
>> > cells: 15427500
>> > Le ven. 9 nov. 2018 à 07:16, Francois Chartier <fra.chartier at gmail.com
>> > <mailto:fra.chartier at gmail.com>> a écrit :
>> > does anybody know how to resolve this?
>> > On Thu, Nov 8, 2018, 06:23 Francois Chartier <
>> > <mailto:fra.chartier at gmail.com> wrote:
>> > Hi,
>> > I am trying to use V.VOL.RST to interpolate particle size for
>> > soil samples. i obtain the error message to increase DMin.
>> > unfortunately i have a data point every meter vertically and a
>> > total of 190K. if grass is asking to increase DMIN, which i
>> > have increased to 30 m to try to see if this was the pb, can I
>> > resolve this by reducing the Segment size?
>> > * COMMAND OUTPUT*
>> > (Thu Nov 08 06:17:32 2018) Command finished (10 sec)
>> > (Thu Nov 08 06:20:40 2018)
>> > v.vol.rst input=geotechNov8 at Toronto wcolumn=dbl_2 npmin=50
>> > npmax=200 dmin=30 elevation=Geotech3DNov8
>> > (Thu Nov 08 06:20:51 2018) Command finished (10 sec)
>> > *METADATA*
>> > Thu Nov 08 06:11:32 2018) Command finished (0 sec)
>> > (Thu Nov 08 06:19:17 2018)
>> > v.info <http://v.info> map=geotechNov8 at Toronto
>> > | Mapset: Toronto
>> > | Location: Toronto
>> > | Database: C:\Users\Francois
>> > Chartier\Documents\grassdata |
>> > | Title:
>> > | Map scale: 1:1
>> > | Name of creator: Francois Chartier
>> > | Organization:
>> > | Source date: Thu Nov 08 06:06:56 2018
>> > | Map format: native
>> > centroids: 0 |
>> > boundaries: 0 |
>> > islands: 0 |
>> > kernels: 0 |
>> > 0 |
>> > | Map is 3D: Yes
>> > | E: 651697 W: 609201
>> > | B: 0 T: 352
>> > | Comment:
>> > (Thu Nov 08 06:19:18 2018) Command finished (0 sec)
>> > N �n�r����)em�h�yhiם�w^���
> www.avast.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181114/49b563cd/attachment-0001.html>
