[GRASS-user] need help computing all flow routing for large DEM
Markus Metz
markus.metz.giswork at gmail.com
Thu Nov 22 00:25:11 PST 2018
On Wed, Nov 21, 2018 at 9:40 AM Ken Mankoff <mankoff at gmail.com> wrote:
> Hi Markus,
> > On 2018-11-20 at 09:56 +0100, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> >> You don't need r.watershed or r.terraflow for this purpose., You can
> >> run r.stream.extract with a DEM as the only input, then you get the
> >> outlets and can feed them to r.stream.basins.
> Thank you for suggesting this workflow. It works well and quickly!
Strange. r.stream.extract is usually a bit slower than r.watershed.
Markus M
> -k.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181122/80e4a8e9/attachment-0001.html>
